跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Screw Size and Diagram
Hiya Everyone,
Hopefully someone will be able to help, basically I accidently knock my screws of my magnet board when repair my iPhone 5s. So now I don't know which screw goes where does anyone have a diagram that states the size of the screw or any advice on what to do
Thank you all.
Update
thank you guys, appreciate the help.
I have one other question I have a little rubber square and I'm not quite sure where its come out from and can not see it on the guide any ideas?
Thank you in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
This rubber square comed from the microphone hole on the lower part of the phone. It's internal and protect the microphone from the dust.
https://images-na.ssl-images-amazon.com/...
完成的
添加一条评论
4个答案
已选择的解决方案
Hi Sam,
Are you following an iFixit guide?
If not, go to that page, choose the guide that you need, and you will see that there are steps that indicate what screws go where, and their respective sizes. You will need an accurate measuring tool such as this caliper to measure the length, and trace each screw back to it's original place in the phone.
The most important screws to watch out for are those that hold the shield covering the screen connectors.
If in doubt, don't put any there. If you use a screw that's too long, it will rip through the board, potentially breaking traces within the board and causing very expensive damage.
Accurately measure small screws and parts.图片
产品
Digital Caliper
$39.99
这个答案有帮助吗?
得分 1
添加一条评论
It's the rubber for the mic. Goes between the headphone jack and the charge dock.
这个答案有帮助吗?
得分 1
添加一条评论
That little rubber square goes at the bottom of the iPhone it holds a flat ribbon in place but it is not absolutely necessary
这个答案有帮助吗?
得分 1
添加一条评论
Sam, the individual guides on here list the screw size with each step.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 13
总计 21,333
