跳转到主内容
加入维修社区 - 创建账户
A swimming pool is a container filled with water intended for swimming or water-based recreation.
motor won't start, just hums
I have an emerson eb654 pool pump. The motor was turned off for cleaning, about 15 minutes. It had been running fine for 3 years. When I went to restart motor, all it will do is hum. motor shaft turns freely with no obstructions. all connections clean and dry. thanks, Rob.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
Hi, I am including a link to a troubleshooting guide for pump motors. From what I read it sounds like the starting capacitor is bad. Arrow down to the troubleshooting section. Good luck Ralph
http://www.swimmingpoolparts.net/pool_pu...
这个答案有帮助吗?
得分 2
2条评论:
完成的
very nice link +
完成的
添加一条评论
Last year, mid season, I had the same problem. The motor seized - most likely bearings.
Since the pump was 10 years old, I opted to replace it. Now I have a quieter, more efficient and cheaper to buy top of the line pump.
这个答案有帮助吗?
得分 0
添加一条评论
The motor turns freely likely it will run if you spin the shaft "Caution" I have cycled the low speed button and it started. Thinking it is start capacitor though I have not located a new one yet
这个答案有帮助吗?
得分 0
添加一条评论
definitely the capacitor
这个答案有帮助吗?
得分 0
添加一条评论
Most likely is a bad motor start capacitor. I will call a swimming pool company or if you're handy you can try to do it yourself with a good youtube video.
这个答案有帮助吗?
得分 0
1条评论:
@poolguy we are a self-help forum, not a platform for advertising your business. Please answer users' questions with help the user needs to immediately fix their problem themselves. Do not include a link to your service.
Please feel free to advertise your personal services on your profile page. We ask that you do not put personal links in our Answers forum.
you should always try to help people, if no one gives things up for others we will all end up like the bear that left, stay caring and good
完成的
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 23
总计 27,524
