跳转到主内容
加入维修社区 - 创建账户
LG Optimus L7 P705 配备 4.3 英寸 LCD 屏幕,重 4.3 盎司。它拥有 500 万像素摄像头和 LED 闪光灯。内置 4 GB 存储空间,并配有一个最高支持 32 GB 的 SD 卡槽。
restore my phone software
i do have lg p705 and i forget my lock pattern and google account.i did hard reset but i am not able to do hard reset.what should i do to regain my mobile as earlier without doing hard reset?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
1条评论
由完成的 分享
添加一条评论
3个答案
最有帮助的答案
If your device is rooted, there are various apps you could run to remove the screen lock. Root it, enable adb on your device so your computer could recognize it and attempt to unlock it.
Otherwise just perform a hard reset via recovery mode on your
1. When the phone is switch off , press and hold the VOLUME DOWN key + POWER key with your left hand.
2. When the LED on the bottom of the phone lights up, touch and hold the MENU key with your right hand. You need to do this immediately, before the screen displays the LG logo. Make sure your left hand is still holding the VOLUME DOWN and POWER keys.
3. Then release the POWER key at vibration time.
4. When the LG logo is displayed on the screen, continue to hold the keys for around 2 seconds,
and then release all them at the same time, before LG logo disappears.
5. Leave your phone for at least a minute while the hard reset is carried out .You will then be able
to switch your phone back on.
CAUTION: If you perform a hard reset , all user application and user data will be deleted.This cannot be reversed. Remember to back up any important data before performing a hard reset.
这个答案有帮助吗?
得分 5
添加一条评论
how to open pattern lock lg p705
这个答案有帮助吗?
得分 2
添加一条评论
Yes it will be enternally greatful
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
angikar acharya 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 37
总计 9,200
