跳转到主内容
加入维修社区 - 创建账户
本田 Element 是一款基于改良版 CR-V 平台打造的紧凑型跨界 SUV,由俄亥俄州东自由城工厂制造,提供前轮驱动和全轮驱动版本。
How repair engine coils
my car is stalling out Could the 4 engine coils be the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Is your Check Engine Light on? Have you tried to get it scanned for any error codes? Unlikely that all your coils failed at the same time.
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Possible, you should get a cheap OBD 2 scan tool to check for mis-fire DTCs in the system. But the easy way to check for misfire codes is to look at the mil light when the car is running. misfire will make the mil light flash.
这个答案有帮助吗?
得分 1
添加一条评论
By any chance do you drive a standard? Elements, especially those that are sticks, tend to suffer from the exhaust valves going out of spec much sooner than normal. In my experience (the three times this has happened within 130K) is that I would drive semi-aggressively from a cold start. When I came to a stop in the first 5 minutes of driving, the RPM gauge would drop too low and stall. Turning the car back on would keep me moving again for usually the rest of the drive.
You can literally say to the mechanic, "my exhaust valves are out of spec" and they can fix it from there. It's cost me between 150-300 depending on the mechanic doing the work.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
peder Larsen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 19
总计 731
