跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
Lines across bottom of screen
I have 2-3 thin lines across the bottom of my 1st generation iPhone. It does not prevent me from moving the lock screen button and getting on to the main screen, but I would like the phone to be in perfect condition. Can you tell me what part needs to be replaced and how difficult a job it is to do??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Here is a list of steps you can try!
  • Software issues
    1. Restore (Google it) Back up first!
Or
  • Hardware Problems
    1. Bad Screen (Change It!)
    2. Bad Logic Board (Change it too! HARD and Back Up first!)
Hope I helped!
这个答案有帮助吗?
得分 1
添加一条评论
Original iPhone front screen replacement is among the most difficult iPhone repairs there is. Watch a few youtube videos to see the process. Unless you have extreme skill, you will not even be able to open this iPhone without permanent damage to the iPhone case. In the future, if the battery eventually fails, battery replacement is much easier, but again, a very difficult process. The Original iPhone is not a repair friendly iPhone.
这个答案有帮助吗?
得分 0
添加一条评论
I assume it is CHEAPER if you buy a used NEWER iPhone for less than 100 € than trying to replace the display !
I have the same problem since several years, and have upgraded first to 3g and now a 4s model in the meantime
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pbassey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 607
