跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Mega 2 安卓智能手机于 2014 年 9 月发布。
Camera Error and USB connection
Keep getting "camera failed" error message. Think I've tried everything..factory reset, clearing cache, undtalling flashlights,etc.. Also cant connect to pc via USB cable. Cannot select the "tethering and usb" function..stays blacked out. I need help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 51
2条评论
might be hardware damage, maybe water damage.
由完成的 分享
I think it's time we all get a new phone
由完成的 分享
添加一条评论
10个答案
最有帮助的答案
Wiping the cache partition did not work till I then pulled the battery and reinstalled...
这个答案有帮助吗?
得分 10
8条评论:
Dear michaelbowerscore1st, thanks for that tip! It worked for me. Sorry, my Samsung. Eternally grateful.
由完成的 分享
Thanks i just pulled battery and it works again.
由完成的 分享
thanks mate , i made an account just to tell you that !
由完成的 分享
This worked. Thank you kindly now!!!
由完成的 分享
omg...thank you soo much it works for me!! Thank you! God Bless you..
由完成的 分享
显示更多的3条评论
添加一条评论
Here's one more trick you might try:
  • Turn your Samsung Galaxy S4 off and hold Volume Up, Home, and Power keys simultaneously until your smartphone starts to vibrate.
  • Let go of Power key and keep pressing the other two.
  • It will get you into Android System Recovery mode.
  • Press Volume Down to choose wipe cache partition and use Power key to select it.
Alternatively another trick I've used in the past:
  • Connect your device to your computer using a data cable.
  • Go to folder: Computer\SAMSUNG-SGH-I747\Phone\Applidium Image Cache
  • Delete everything in this folder.
  • Go to folder: Computer\SAMSUNG-SGH-I747\Phone\Android\data\com.sec.android.gallery3d\cache
  • Restart your phone.
这个答案有帮助吗?
得分 5
4条评论:
My computer cant find my phone.
由完成的 分享
Thank you so much! the 1st method is work!
由完成的 分享
Thank you thank you. It worked on my galaxy mega 2.
由完成的 分享
have tried all this , nothing has worked. Screen freezes & goes half pink/purple.
由完成的 分享
添加一条评论
Im having the same problem as the OP, and tried the cache partition reset but still getting the camera failed error, and cant connect to my PC through USB. Any other ideas?
这个答案有帮助吗?
得分 2
1条评论:
If this doesn't work for you above, then I would suspect you could be dealing with a hardware component failure. The first and cheapest troubleshooting step is to replace the camera assembly. If that doesn't work, you could try the motherboard assembly.
由完成的 分享
添加一条评论
It definitely helped to delete flashlight app and take battery out and restart. Thank you. I now have my camera working
这个答案有帮助吗?
得分 2
添加一条评论
Samsung sm g750h Camera fail
这个答案有帮助吗?
得分 1
添加一条评论
If your mega2 Camera failed
First your mobile phone
Setting>
Date and time>at automatice date and time>mark making
All you do
Go to camera
Testing
Camera failed resolveing
这个答案有帮助吗?
得分 0
添加一条评论
เครื่องซัมซุง แกแลกซี เมกกา2 มีปัญหา camera failedต้องทำอย่างไรค่ะ
这个答案有帮助吗?
得分 0
1条评论:
ต้องการคำตอบจากคำถามค่ะ
由完成的 分享
添加一条评论
Had the same problem with a failed camera message and PC not recognizing USB connection.
Solution - Turn off the phone > Pull the battery > Hold power button for 3 seconds > Reinsert battery > Turn on phone.
Camera works from lock screen, cannot confirm beyond that.
这个答案有帮助吗?
得分 0
添加一条评论
Camera application is lost.What is doing?
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam G 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 35
总计 21,940
