跳转到主内容
Updated in March 2008 with 802.11n Wi-Fi support, the AirPort Express A1264 is a compact and portable wireless network device.
12 个问题 查看全部
Fix for AirPort Express A1264
Hello,
I have an airport Express a1264, it sometimes gives me a few seconds a green light, and then a orange one. I think then it's booting. But after 5 seconds it stops. When I try it again, then it isnt showing me any sign of life. Maybe it's the power supply. Please help me.
Kind regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
First give this a try: Resetting an AirPort base station FAQ.
You may need to reconfigure the AirPort. Download the AirPort Utility from here: Support downloads
这个答案有帮助吗?
得分 2
4条评论:
Hello,
I've done it several times, but the airport is not showing me a light.
I really think it's a hardware failure.
完成的
Can you access it via the Ethernet connection with your Mac running the AirPort utility?
完成的
I'm sorry for my late answer. But no, nothing works, it doesn't show up.
完成的
Ouch! Thats not good ;-{ Sounds like its time for a new unit.
完成的
添加一条评论
Based on your comments on the status LED, most likely, the power supply in the base station has failed.
Ref: AirPort base stations: About AirPort base station status lights (LED)
One possible means to try to revive it would be to perform a "factory default" reset on the base station. You may need to try this a few times. If this fails to solve the issue, you will need to replace your base station.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Diederik De Coninck 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 2,466
