跳转到主内容
加入维修社区 - 创建账户
一款功能完备的专业级 DAT 录音机,多年来已被用于录制许多优秀的专辑。
How do I rescue a DAT?
I have a DAT tape that is stuck in a Panasonic SV–3800 machine. At first, just wouldn't play audio, on this machine or on an SV-3700, but it did at least fast wind. Now the machine won't eject or play or do anything. I have tried powering it up several times. The literature I have seen online is insufficient, so far. I have had experience with ADATs in the past, where you could manually move a wheel inside to guide the tape out, but the wheels I see inside this machine won't budge. It is hard to tell if the tape is damaged, since you can't see it from the outside of the machine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hello, you will need to remove the cover and locate the loading wheel which is on the right rear of the loading carriage, it has the rubber band on it that connects to the loading motor. Start pushing the wheel away from you til the carriage is completely open, from there you can remove the tape if it is not loaded inside up to the drum, if it is you will need to remove the four screws that hold the upper carriage to the base and manually pull the upper carriage off and remove the tape.
这个答案有帮助吗?
得分 0
1条评论:
OK, I have an SV3900 Panasonic DAT and While I can take the screws off the side and back, the front top will not release. Now what?
由完成的
添加一条评论
添加你的答案
Rich Lamb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 1,592
