跳转到主内容
加入维修社区 - 创建账户
Suzuki FA50 助力车维修与故障排除信息。
Why is the engine bogging under acceleration?
I recently managed to get the moped running properly, albeit for only a short time. Things were looking up: I replaced the spark plug, cleaned out the exhaust, adjusted the idle / fuel screws, and even replaced the brakes (I can stop now!).
So everything was looking good. I was test-riding it after a short hiatus, and the moped was running fine. Near the end of my ride, I stopped at an intersection to make a left turn. I revved the engine while still stationary in anticipation of the light turning green -- I didn't want to hold up traffic, and the 50cc engine takes a while to get going. I pushed off from standstill, the scooter started moving fine, but soon thereafter started lagging. It absolutely refused to go past 20 MPH even though I'd usually go 27-28 on the same stretch of road. It was consistently going slower afterwards, and I scurried back home as best as I could.
I've revved the engine like this in the past (with the moped stationary), but for shorter durations. This time I'd say I was on full throttle ~5-10 seconds while stationary.
A couple of days later I fired it up, but it ran horribly. I managed to get it moving, but it hit 10-12 MPH on mostly flat land (where 27 MPH was common). It felt as if the engine was providing power for a couple of seconds, then stopped the power delivery for a couple of seconds, and it kept doing this over and over. It was so weak that I had to push it up a hill to get it back to my residence.
I thought -- for just a second -- that I smelled a burning clutch when I was riding it back home after the intersection incident. After I got home, I "smelled" around, but couldn't pick up any burnt clutch scent.
I sincerely hope the clutch isn't the culprit, since it's an expensive fix. Please let me know if you have any ideas as to where I can start troubleshooting (aside from the clutch, of course), as the weather's nice and I'm hoping to get it going this weekend -- fingers crossed!
7/10/10 Update
I swear guys, I'm not crazy. There was a problem with the moped.
This morning I fired it up the usual way, hoping to analyze how it runs. It hit 29 MPH on flat land like nobody's business and I rode it around for a good half hour with no problems. I have no idea what changed in the last couple of weeks -- perhaps it had some time to think about its problems and resolved them.
I have a feeling this won't be the last time this problem pops up. I will most likely be coming back to this post sometime in the future :)
Thanks for all the replies!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
20条评论
Try holding the choke while running at a good speed (15-20 mph). If running improves, you probably have an air leak in the engine.
完成的
+ very well stated question. You should write manuals ;-)
完成的
I find none of the answers acceptable except the condensor because the problem occurs when the engine gets hot.
A fuel problem would be constant as well as dirty carb, clogged hoses, leaking intake, so the problem is related to the heat which is prolly the points/condensor
完成的
Check for fuel lines too close to a heat source causing vapor lock
完成的
I had this problem this morning, but i seem to have a leak coming from my air cleaner/muffler, i have a tgb r125x
完成的
显示更多的15条评论
添加一条评论
9个答案
已选择的解决方案
Always start with checking for strong spark, a bad condenser can put out strong spark when cold, but will quickly fade. Arcing across the points is a good indication of a bad condenser. Assuming that the ignition system is in tip-top shape, that sounds like a fuel related issue.
I would start with checking fuel flow, as well as the fuel level in the tank. With a gravity feed fuel system, a clogged gascap vent, or misrouted/to long of a fuel line are common culprits, especially as the fuel level gets lower in the tank. If the tank is venting properly, and fuel flowing well to the carburetor, I'd clean the carb.
Pay close attention to the small holes in the carburetor jets, just because you can see light through the hole does not mean it's not restricted by residue left from evaporating fuel causing a lean fuel mixture. Poking a small piece of soft copper wire through all the holes, followed by a good blast of air or carb cleaner works well. Do not use steel or anything to hard to clean out the jet, you may accidently enlarge the jet, changing the fuel mixture.
If the bike does not idle smoothly or takes a long time to settle back down to idle speed, and you've already cleaned the carburetor, you may have an airleak. Airleaks can be caused by a bad seal in the engine, or in the intake/carburetor joints. You can sometimes track down an airleak by spraying carburetor cleaner on a suspect sealing/joint area and listening closely to see if the engine RPM's change (sucking carb cleaner fumes into carburetor will also do this, so be careful when working near the carburetor).
Hope those suggestions help!
这个答案有帮助吗?
得分 10
8条评论:
+ awesome
完成的
+ excellent, please come back again.
完成的
+ Ralph
完成的
Can I put in rubbing alcohol in my fuel tank to help my 50 cc stop shaking and shuttering
完成的
no ethanol in a 2 stroke.
完成的
显示更多的3条评论
添加一条评论
Drain the gas tank completely and wash it out with some fresh gas. Condensates from sitting for a long time may have clogged the hoses and filters plus you may have some water condensation in the lines now or particulate matter.
这个答案有帮助吗?
得分 4
7条评论:
+ Ralph
完成的
so pretty much idleing fine then dying when trying to accelerate can be caused by bad gas. good to know ill try a fresh tank from a different station than the last tank. i was running fine then filled my tank and it started its crap
thanks
完成的
If there was water in the gas, you may need to drain your tank and carburetor float bowl. The water is heavier the gas and sits at the bottom of your tank and float bowl. Shine a bright flashlight into your tank, can you see anything that looks like bubbles floating at the bottom? That will be water. It can also get trapped in your fuel filter and cause issues.
完成的
clean ur carb and check spark plug as a good spark and clean.checks leads 4 damage.fuel tank filter clean.
完成的
u said u played with the timing on the carb if its not r8 it could cause the bike to run crap.
完成的
显示更多的2条评论
添加一条评论
Well I think you should spray started fluid then clean off spot plug and spray hoses and make Sure your hoses are tight
这个答案有帮助吗?
得分 1
添加一条评论
My fa50 Suzuki 1985 had the same prob, i could rev it a lil but as soon as i revved it while on it, it would cut off. My neighbor suggested that all older motorcycles have same issue. Simply get your hammer and tap away. I tapped the carborater and the thing next to the carborater pretty good and it started up and ran faster than b4! It is suppose to loosen a needle that controls gas flow.
这个答案有帮助吗?
得分 1
1条评论:
my son was having trouble with his new 150cc, I tried everything I knew without any luck, then I saw the post about beating the carb, I should have thought of it myself since I work on cars, but since they got rid of carbs, guess I forgot old school methods work great on old school parts, lol
Thanks for reminding me.
完成的
添加一条评论
I had the same issue with my SYM Euro Jet, I had cleaned the carb and exhaust. However still bogging out, I took it in to a shop for service, they said sell for parts.
What I ended up doing was replace the seals on the Piston head and Exhaust myself and it has been running fine for another $8000ks :-)
Update
I have also fallen victim to cheap 2stroke Oil, which was found to cause buildup on the Spark Plug and in the Exhaust. Never again
这个答案有帮助吗?
得分 1
添加一条评论
A small engine like that that idles ok but bogs under acceleration is usually one of three things; 1) air leak at the intake boot. A squirt of starter fluid at the boot while running will tell you. If it revs you have a vacuum leak. 2) the main jet is clogged (it could also be the main jet is too small but sounds like it was previously fine, so that’s unlikely) you’ll need to take the carb apart and give it a good cleaning. It’s not hard to do, it just takes some time.
这个答案有帮助吗?
得分 0
1条评论:
I missed the 3d possibility?
完成的
添加一条评论
I have a 50 cc moped new carb an spark plug every so often it will bog out an die. Then it's hard to start what could it
这个答案有帮助吗?
得分 0
1条评论:
It's got a brand-new air box an the shop put the carb on an adjusted the carb. It was running great for 3 days then started bogging out again
完成的
添加一条评论
For some reason the air fuel mixture isn’t right, too much air not enough fuel. Is the carb tight on the intake boot? Is the air filter clean? If its a new carb is the air/fuel screw set correctly for your scooter- generically 1 1/4 turns out.
这个答案有帮助吗?
得分 0
5条评论:
hi I have a ruckus that rides fine up to 20mph then just wont accelerate at all and seems to lose power until i let the gas off and then it'll accelerate fine up to 20 again...can anyone help..thx
完成的
Sounds like your timing is out.
完成的
I will post comment later if helps.im off to work.
完成的
@Jimmy Loizeau Mine is doing the exact same thing!! It will get to about 30 mph no problem, but then immediately begin to loose acceleration and slows way down. Then, if I let go of the gas and let it idle almost all the way down and then hit the gas back, it shoots right back up to about 30 mph only to drop speed right back down repeating the same process over and over. My mechanic tried everything you can think of to no avail. Now he's saying it is probably the timing chain because he eliminated all the little issues it could have been. I wish I knew for sure and that he wasn't ripping me off, but most people on this thread have not brought up the timing chain, so it's not giving me the advice I was hoping for. Wish someone knew more on here
完成的
I have a 2014 jonway 150cc it's got a new 180cc motor in it I can go 75 mph she runs like she's brand new 2 days ago for no reason I would stop for a light and she shakes bad like she's gonna stall but don't I can't explain the rhythm of shake but it has one please help
完成的
添加一条评论
The engine bogs under acceleration usually due to a fuel or air delivery issue, such as a clogged fuel filter, dirty air filter, faulty fuel pump, or a problem with the carburetor or fuel injectors. It can also be caused by ignition system issues like bad spark plugs or timing problems.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Miroslav Djuric 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 126
总计 461,999
