跳转到主内容
A range of desktops aimed at the mainstream consumer market, spec-wise situated between the Inspiron and XPS lines released in 2009.
Can I close my laptop after dropping it?
My Dell Studio laptop fell to the floor while it was on. It still works great, but makes a noise when I start to close it. So I don't close it! I turn it on and off, but don't close it.
The only physical damage appears to that the left-side hinge, or pivot, is not firm, and the metal cover is slightly bent.
Question:
Can I go ahead and close the laptop completely, or might that cause some further damage internally, making it inoperable?
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Post an image of your damage with your question. right now I would suggest not to close it since it may tear the hinges from the casing etc.
完成的
How do I post an image? I tried 'Copy' and 'Paste'.
Thanks.
完成的
添加一条评论
1个答案
最有帮助的答案
strodney, yes you can, but not for very long. the hinge definitely looks unstable and eventually will break all the way. That would leave your display hanging on one hinge. I suggest that you replace it pretty soon.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
strodney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 133
