跳转到主内容
加入维修社区 - 创建账户
1.8 或 2 GHz G5 处理器,最高支持 2GB DDR1 系统内存
Schematic for black inverter cable that connects to logic board
I am attempting to salvage an iMac G5 20" Model A1076. Upon reassembly the black cable with six wires that connects the Inverter to the logic board  disconnected from plastic six prong female plug where cable plugs into logic board. Is there a schematic that provides the proper pin-out for the six wires that attach to the logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
eli Lucas, you will have to post an image of your inverter and the cables with your question. The wiring on your connector from left to right is:
24V
24V
Ground
Ground
Brightness
3.3V
an image of where the cables are connected on the inverter should help to figure out which wire is what.
这个答案有帮助吗?
得分 2
2条评论:
I reversed engineered other Apple wiring harnesses and each seems to follow the same pattern. When positioning the wire receivers in the same orientation, the cable order follows the same orientation in each plug.
完成的
Thank you for your knowledge and time!
完成的
添加一条评论
See if the installation guide answers your problem: iMac G5 20" Model A1076 逆变器更换
这个答案有帮助吗?
得分 1
2条评论:
I am eternally grateful for your time and wisdom. The small black cable that consists of six small black wires inserted into a plastic plug is the problem. The six wires became separated from the plastic plug and I do not know which order to reassemble the wire harness to the plastic plug. Any ideas?
完成的
I've done the same thing. My solution was to just order a new cable. But OldTurkey has the solution.
完成的
添加一条评论
添加你的答案
eli Lucas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 568
