跳转到主内容
加入维修社区 - 创建账户
2007 年款的 Escalade 换用了全新的 GMT900 平台。
replace the lamp above my right headlight
Step by step instructions on how to replace the small lamp above the headlight on the right side of my Escalade. I am a a single female doing it for the first time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Sounds like someone else has had this same question on this forum. In my experience, though, you should be able to unscrew the dust cap from the back of the headlight housing where the connector is to replace just the bulb. I, unfortunately, do not have an Escalade in front of me to see if this is also the case. From looking around at a few different places, it seems it might take some more work.
Something else you might try is going to your local Autozone, show them the bulb that needs to be replaced, and have them take a look at it to see if it's a simple install.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Pat Kerbs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 18
总计 3,622
