跳转到主内容
加入维修社区 - 创建账户
Acer Iconia One 7 是一款于 2014 年 4 月发布的平板电脑。 Iconia One 7 是一款小巧精致的娱乐设备。它配备了一块比平板手机更大、既清晰又色彩鲜艳的显示屏,响应迅速,且拥有长久的电池续航时间,可满足你的日常使用需求。我们还内置了 Kids Center 平台,提供大量有趣的儿童内容,并允许家长进行管理。
Acer Iconia One 7 Screen Digitizer Video Tutorial
Could you please make a Screen Digitizer replacement video Tutorial for Acer Iconia B1-730 ? is there any model that has similiar process of digitizer replacement and already published in your youtube channel ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
Hi There, I am looking for the exact same tutorial. Were you able to locate one?
这个答案有帮助吗?
得分 1
添加一条评论
I haven't found one. So I tried myself the replacement seeing similar tutorials with great success. Now, the tablet is working again with a new digitizer, however I still have a problem with the screen calibration. The digitizer is working good, however when I point my finger on it, the command is recognized in a different position, some centimeters above from my finger position. Anybody knows how to fix it ?
这个答案有帮助吗?
得分 0
5条评论:
Hi, Did you ever sort this - I am doing a repair and have the same issue! on two different digitizers!
由完成的
Nop. Problem still remains.
由完成的
I have decided that the digitizers sent are not 100% correct. They appear to fit perfectly but they do mask the edges of the lcd slightly. Tried a 3rd digitiser and still the same issue. I have a new tablet coming and will compare the digitiser measurments.
由完成的
Looks like the only available digitizers are not 100% the same size, The side borders are too wide so obscure some of the lcd and the heights are a bit thick too. Has anyone replaced a digitizer with a ebay special and it work ok?
由完成的
Hi Jon... the same happened here with my digitizer. The measures is not the same like the original one.
由完成的
添加一条评论
I want to repair my acer iconia tab 8 but i dont know where to found à new screen cam someone help m,e :( ?
这个答案有帮助吗?
得分 0
添加一条评论
I wanna ask on what button should I select to organize my apps?? Thank you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ricartengenheiro 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 18
总计 2,485
