跳转到主内容
The Acer Iconia One 7 is a tablet released on April 2014. The Iconia One 7 is a compact package full of media fun. With a bigger-than-phablet display that is both clear and colorful, you get speedy response and hours of battery life to keep things going. We’ve also included our Kids Center platform with lots of cool kid’s stuff that parents can control.
44 个问题 查看全部
Acer Iconia One 7 Screen Digitizer Video Tutorial
Could you please make a Screen Digitizer replacement video Tutorial for Acer Iconia B1-730 ? is there any model that has similiar process of digitizer replacement and already published in your youtube channel ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
Hi There, I am looking for the exact same tutorial. Were you able to locate one?
这个答案有帮助吗?
得分 1
添加一条评论
I haven't found one. So I tried myself the replacement seeing similar tutorials with great success. Now, the tablet is working again with a new digitizer, however I still have a problem with the screen calibration. The digitizer is working good, however when I point my finger on it, the command is recognized in a different position, some centimeters above from my finger position. Anybody knows how to fix it ?
这个答案有帮助吗?
得分 0
5条评论:
Hi, Did you ever sort this - I am doing a repair and have the same issue! on two different digitizers!
完成的
Nop. Problem still remains.
完成的
I have decided that the digitizers sent are not 100% correct. They appear to fit perfectly but they do mask the edges of the lcd slightly. Tried a 3rd digitiser and still the same issue. I have a new tablet coming and will compare the digitiser measurments.
完成的
Looks like the only available digitizers are not 100% the same size, The side borders are too wide so obscure some of the lcd and the heights are a bit thick too. Has anyone replaced a digitizer with a ebay special and it work ok?
完成的
Hi Jon... the same happened here with my digitizer. The measures is not the same like the original one.
完成的
添加一条评论
I want to repair my acer iconia tab 8 but i dont know where to found à new screen cam someone help m,e :( ?
这个答案有帮助吗?
得分 0
添加一条评论
I wanna ask on what button should I select to organize my apps?? Thank you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ricartengenheiro 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 2,064
