跳转到主内容
加入维修社区 - 创建账户
这是佳能于 2011 年推出的一款便携式数码相机。
Why am I getting a Lens Error?
When I turn the camera on, the lens stays extended and the LCD screen displays "Lens Error/Will shut down automatically/Restart now." I've tried turning the camera off and on again but the error still displays. When the camera is off, the lens remains extended.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
See more suggestions below - lens assembly replacement almost always works.
由完成的 分享
Sometimes, the lens mechanism can get stuck or misaligned. With the camera turned off, try gently tapping or shaking it (not too forcefully) to see if it helps free up any obstruction or realign the lens. Be careful not to apply excessive force or impact that could further damage the camera.
由完成的 分享
添加一条评论
5个答案
已选择的解决方案
This is a known error with the Canon PowerShot S100 camera. For more information, you can visit Canon's press release here or you can attempt to fix it here.
Here is a link to our troubleshooting section about this issue.
这个答案有帮助吗?
得分 2
添加一条评论
Replacing the lens assembly will almost always fix this error if simpler fixes don't succeed. See my guide for the process here: Canon PowerShot S100 Lens Assembly Replacement.
这个答案有帮助吗?
得分 1
添加一条评论
Canon will not fix my camera because of rust and corrosion. I am warning people not to send their camera back. They are trying to get out of actually fixing the situation by forcing an out of warranty repair. I barely used this camera so I know that the rust and corrosion is not something I caused.
这个答案有帮助吗?
得分 0
1条评论:
If Canon won't fix it, go with this place. They have serviced multiple cameras for me and they are excellent (about half the price of Canon).
This is who I used: www.camerasandparts.com
Good luck with the problem
由完成的 分享
添加一条评论
remove the battery. close the terminal. hold the on/off button for 1 minute. replace battery. turn on and use.
这个答案有帮助吗?
得分 0
1条评论:
your solution doesnt work
由完成的 分享
添加一条评论
I fixed my Canon PowerShot S110 with the vacuum cleaner. I turned on the vacuum, placed the hose over the lens, turned the camera on and off and hooray . . . it worked! Good luck fixing yours. Kathie
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ricky 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 105
总计 36,024
