跳转到主内容
加入维修社区 - 创建账户
Warp 4G 于 2013 年 10 月发布,是一款 Boost Mobile 网络专用的经济型智能手机。
How do I fix a black screen?
The phone started vibrating and wouldn't stop. I took out the battery and left it out overnight. The vibrating finally stopped but now the screen is completely black.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 30
添加一条评论
2个答案
已选择的解决方案
Has the phone been dropped or exposed to liquid or any other damage that may have brought on these issues? If you have a warranty still in place I would take the phone in and have it repaired or replaced. If not then try these steps:
If you have your data backed up or don't care about loosing your saved data then you might want to try a hard reset/factory reset. There are three different ways to do this but I am going to mention one because the other two ways require a viewable screen. A hard reset can fix a number of issues with phones but do not always solve the problem.
Make sure, that your phone is off.
Now press and hold these buttons: Volume Down + Volume Up + Power key.
Next from the menu choose "Wipe Data/Factory Reset", using Volume buttons to scroll to option, and Power button, to confirm operation.
Then select "yes", and confirm with Power button.
After that press Power button to enter option "reboot system now".
If this doesn't help then you may want to disassemble the phone and look at the connections inside the phone. Your LCD may have a loose connection and may need to be reseated or it may have been damaged and need replaced.
这个答案有帮助吗?
得分 10
4条评论:
what worked for me was letting the phone dry then trying to factory reset. after it opens the option press and hold the power button and it will restart with a viewable screen.
完成的
but what if you can't see the screen to choose anything from the menu? I changed the battery successfully and it's finally holding a charge, but I can't see a thing.
完成的
Same problem
完成的
Porcelain Princez if you followed the correct answer and still have the same issue it is most likely that you a loose connection to your LCD ir a failed LCD
完成的
添加一条评论
All i did was open it up and reseat the lcd connection on the board.
这个答案有帮助吗?
得分 3
2条评论:
I have the zte but when you do the steps the screen still black so I can’t see to reset . What now ???
完成的
I have the ZTE but when u do the steps the screen still black so l cant see to reset amd do anything. What should I do now
完成的
添加一条评论
添加你的答案
jalynn062604 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 25
总计 44,269
