跳转到主内容
加入维修社区 - 创建账户
这款多用途 Android 平板电脑发布于 2013 年 5 月。它配备 7 英寸 800x480 分辨率液晶显示屏,采用双核处理器,并支持最高 32GB 的扩展内存。
Why does my device keep shutting down?
I've had my tablet for a few months now and recently after being used for a while, it randomly shuts down. When this happens it usually won't come on for another couple of minutes and then simply repeats the process. Any help would be appreciated!
Update (08/04/2018)
My tablets gets to the @9 dualcore screen then stops and shuts off and its a stealth g2 tablet
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
由完成的
I would like to return it back for it to be repaired. Would like a mailing address.
由完成的
I have a triosmile 10 in elite tablet. It takes for ever to download apps. Then once it does the apps don't open then it freezes up and shuts down. Then takes several minutes to restart. I received as a gift. What can I do to fix problem. I have reset and reset back to factory but it still does the same thing
由完成的
@lindatw
ifixit does not sell your tablet or do repairs to any equipment or devices.
I suggest that you contact the retailer from where you got it or check what it says in the user manual about how to contact the manufacturer when you have problems with products that are still under warranty.
由完成的
添加一条评论
2个答案
最有帮助的答案
The most common reason for this to occur is because the battery is done. The life of a battery was never designed to last for a long time, so there is a high chance that the battery needs to be replaced. A guide to the replacement of the battery can be found here.
This could also be related to another problem with the device.
Be sure to check out the Troubleshooting page for more information.
这个答案有帮助吗?
得分 2
添加一条评论
I get a lot of about Why does my device keep shutting down. And thanks for sharing useful information. ''https://procana.com/
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Antoninus Lamptey 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 30
总计 2,108
