跳转到主内容
加入维修社区 - 创建账户
HP Pavilion dv6000 的维修和故障排除信息,这是 HP Pavilion 系列中的一款 HP 笔记本电脑。于 2007 年 4 月发布。
Not Turning on , No Power
My laptop is not turning on. I dont see any power light or any activity when i try to turn on.
Pls help me if you can....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hello,
What have you done/tried already??
Try this:
1/ Remove adapter and battery,
2/ press power button for 30 seconds.
Re-attach adapter but not the battery. Press power button.
If laptop works, change your battery.
If laptop does not startup, check and messure power adaptor,
eventually try another adaptor.
If this does not help,
messure power at inside powerconnector.
Good luck.
Greetz, Pierre
这个答案有帮助吗?
得分 2
5条评论:
I tried but it did not work ...Before I just disassemble it and after cleaning reassemble it with same way.
完成的
What was the reason to take it apart?
If it worked before, it should work again.
Check all connectors again and retry.
Good luck.
完成的
It was working but with one problem ... it was randomly turning off so i try to clean up fan and ventilator ..
完成的
have u tried to disconnect ur power jack, and powering it on with out?
完成的
You wrote:
"...it was randomly turning off..."
Was this a thermal problem?? Did your laptop overheated?
Did you put new heatpaste on the cpu when reassembling?
Hope you find the cause and can solve this issue.
Greetz
完成的
添加一条评论
Hello,
I own this very same computer, and I replaced the A/C adapter just a few months ago, when you plug the computer in, does the ring, around the power input, light up blue? Because if not, your computer is not getting a charge, so no matter what you do, it's not going to turn on. There are many guides here on iFixit on how to disassemble this computer down to the very shell it lies in, if you wan't to attempt replacing it too. I think this may be your problem, as this computer is notorious when it comes to the sensitivity of that A/C input.. I sure hope this helps.
-Samantha S.
这个答案有帮助吗?
得分 1
1条评论:
do u get any beeps codes? take ur ram out and see if u get a beep codes. if not most likely u got mobo issues
完成的
添加一条评论
添加你的答案
AayJay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 2,017
