跳转到主内容
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 个问题 查看全部
Do I need to replace my motherboard?
Hi,
I have Toshiba t135 laptop, when I charge the battery, the LED is lighting so its not the problem, when I press the power button, the LED light comes on but nothing happen, and no fan spinning, no hard drive sound, no beep sound just a quick blink light of power button and the LED lights.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Makely, start by doing this Turn off the laptop then remove the battery and the charger.
Connect the charger back leaving the battery out.
If it is just a simple power glitch then, it will be resolved. Let us know what happens.
完成的
Thank you for the respond oldturkey03, I tried it already but same thing happen. What should I do with this?
完成的
I removed my machines C-mos battery? Then return it to its rightful place. Yes, th perfect solution nd it worked.
Ones my pieced my machine together, I powered it back on. There weren’t any blinking led’s, with my screen back on. I got a display message something about; your c-mos battery is removed, blah blah. Ignored that nd entered F2, 4 setup nd configured my dates Oh, nd make sure your machines battery is having power for when you turn it on, nd lastly make sure your Critical Battery Wake-up setting is disabled in th C-mos setup. That should come as a recommendation, Yawl ar welcome.
完成的
添加一条评论
2个答案
已选择的解决方案
Makely, the T-130 series had a recall for a faulty harness. Check to see if this applies to your computer "Certain Satellite T135, T135D and Satellite Pro T130 laptop computers have been manufactured with a potentially faulty DC-In harness. These computers will have model/part numbers beginning with PST3AU, PST3BU, or PST3LU. " If so, I'd give Toshiba a call and see if they can still help you. No you do not need to send it to a repair center. If you are halfway handy, follow this video to get to it. You most certainly do not need to replace the LCD as previously suggested or implied:-).
这个答案有帮助吗?
得分 1
添加一条评论
Not something you would want to replace your self there are many connections and the back has to come off the screen to replace it I would use a A+ certified Technician who has experience with this repair. I have done them however I am in Gainesville, Fl
这个答案有帮助吗?
得分 0
2条评论:
frankduffey, explain your answer on this one. Sounds to me like you want to replace the LCD. Why?
完成的
yes, I know but what I mean is should I turn this thing into the repair shop to replace the motherboard or there is something easy to fix it that I can do. PLease HELP!!!
完成的
添加一条评论
添加你的答案
Makely 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 1,059
