Do I need to replace my motherboard?
Hi,
I have Toshiba t135 laptop, when I charge the battery, the LED is lighting so its not the problem, when I press the power button, the LED light comes on but nothing happen, and no fan spinning, no hard drive sound, no beep sound just a quick blink light of power button and the LED lights.
3条评论
Makely, start by doing this Turn off the laptop then remove the battery and the charger.
Connect the charger back leaving the battery out.
If it is just a simple power glitch then, it will be resolved. Let us know what happens.
由 oldturkey03 完成的
Thank you for the respond oldturkey03, I tried it already but same thing happen. What should I do with this?
由 Makely 完成的
I removed my machines C-mos battery? Then return it to its rightful place. Yes, th perfect solution nd it worked.
Ones my pieced my machine together, I powered it back on. There weren’t any blinking led’s, with my screen back on. I got a display message something about; your c-mos battery is removed, blah blah. Ignored that nd entered F2, 4 setup nd configured my dates Oh, nd make sure your machines battery is having power for when you turn it on, nd lastly make sure your Critical Battery Wake-up setting is disabled in th C-mos setup. That should come as a recommendation, Yawl ar welcome.
由 frankduffey 完成的
