跳转到主内容
The Samsung NaviBot SR8855 is a handy autonomous vacuum by Samsung.
18 个问题 查看全部
How to disassemble Samsung navibot SR8875?
Hi,
Would like to know how to remove the upper part of the navibot SR8875 ? I removed all screww but still locked in the front ?
If you want, you can also answer me in french (if you're french).
Thanks,
Matt
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
It is a bit tight but it will snap loose.That is if you have removed all the screw around it.
完成的
添加一条评论
2个答案
最有帮助的答案
Hi,
You can find the service and disassembly manual here:
http://www.robotreviews.com/chat/downloa...
Best regards,
Imre
这个答案有帮助吗?
得分 7
1条评论:
Hi,
Thank you all for the link.
Matt
完成的
添加一条评论
Hi
I can send to you a french PDF for that
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
matthieubarbie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 6,147
