跳转到主内容
加入维修社区 - 创建账户
尼康 1230 万像素 DX 格式 F 卡口数码单反相机。
interval shooting timer , not selectable in any menu
I used the IST, once before , when to used it again , but it is not an available option any more. it is gray and all the info that I can get is that it does not work with bracketing settings .. any ideas
thanks
FR
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
I had the same problem with interval not available. Took the 64G card out, 16G in. Interval available again.
这个答案有帮助吗?
得分 1
添加一条评论
had the same issue.. didnt like my memory card.. I had used it week before.. then when I tried to turn on the camera it said the card was not formatted and I know there was data on it.. so now today I took the data off that card. put back in d5000 and it said it was not formatted .. I let it format it.. and now interval is off.. I threw in another SD card and its ok.. doesnt like this micro SD card now.. I have another one I have in there now.. but something is strange.. so try another SD card..
这个答案有帮助吗?
得分 0
添加一条评论
Got the same problem.
- Tried bracketing off
- Tried inserting the date and time again.
- Tried a full battery.
- Tried resetting the camera (hold i button + info button together for a couple of seconds).
- Tried all possible modes and settings.
Then I've read somewhere to somebody had issues due his 64gb card. Now I see Kevin above here say something similair. Back in the day the D5000 came out, 64gb cards were not that normal. So I might buy a cheap 8gb and see if that resolves the problem. If not, I'm out of options.
这个答案有帮助吗?
得分 0
添加一条评论
Hi. I removed the battery and inserted back in and ITS worked again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank RUiz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 2,746
