跳转到主内容
加入维修社区 - 创建账户
Skullcandy Air Raid 是一款于 2013 年 11 月 15 日发布的无线便携式蓝牙音箱,可从任何支持蓝牙的设备进行音乐流媒体播放。
Why wont my device charge?
I have checked my wall outlet and it works perfectly fine with charging other plug-in devices, it just seems to be a problem with my Air Raid. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If the outlet is working and your device is still not charging, you may have a bad USB port. If your device only charges when the plug is held at a certain angle, will not plug in all the way, or has visibly bent/broken pieces inside the charging port, you should replace the USB port. If you have left the Air Raid charging for a long time, but the battery dies quickly after unplugging it, you may need to replace the battery.
这个答案有帮助吗?
得分 1
2条评论:
You should try going to Skullcandy Air Raid Troubleshooting for more troubleshooting help
完成的
Where do i purchase a new battery?
完成的
添加一条评论
@Sasha Nevin, SAME!! IDK what to do about it, but it is really annoying. I've had to use earphones (the ones u stick in ur ear) and was trying to get away from those, however it just won't charge! I also tried charging it through my computer, therefore it still didn't charge
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sasha Nevin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 5,350
