跳转到主内容
Second generation of the Ford Focus.
ac cluch is not turning on .
need to know where is the ac relay and ac fuse is located.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
5个答案
已选择的解决方案
Here is a link to the manual for your car. Scan down to the bottom of the list to where it says download. Fuses and relays are on page 154. Good luck. Ralph
http://www.myacrobatpdf.com/1992/ford-fo...
这个答案有帮助吗?
得分 3
2条评论:
Great research ++ Nobody touched this question for a little bit now. LOL
完成的
atta boy Ralph +
完成的
添加一条评论
A common cause of the ac clutch not turning on is lack of refrigerant gas in the system. There is a pressure switch which detects that there is enough gas and if not the ac clutch won't engage.
这个答案有帮助吗?
得分 2
1条评论:
I 've checked my system and there is no gas in it. How can I force the clutch to engage so I can recharge the circuit?
完成的
添加一条评论
I don't have a answer but I have a mk2 ford focus my a/c clutch wont engage something to do witht he relay not switching?can some one help me please?btinto@hotmail.com
这个答案有帮助吗?
得分 2
添加一条评论
Sometimes due to wear your need to adjust the clutch on the compressor with shims. Most folks miss that and spend a small fortune trying re-gassing and replacing compressors.
这个答案有帮助吗?
得分 1
添加一条评论
what are the steps to adjusting compressor clutch
这个答案有帮助吗?
得分 0
2条评论:
what adjustments are you looking for? What year is your vehicle and what engine size is it?
完成的
same problem here; I can get it going by pressing w a crowbar---but when I release the bar- no go
完成的
添加一条评论
添加你的答案
Tony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 30,317
