ac cluch is not turning on .
need to know where is the ac relay and ac fuse is located.
Here is a link to the manual for your car. Scan down to the bottom of the list to where it says download. Fuses and relays are on page 154. Good luck. Ralph
这个答案有帮助吗?
Great research ++ Nobody touched this question for a little bit now. LOL
atta boy Ralph +
A common cause of the ac clutch not turning on is lack of refrigerant gas in the system. There is a pressure switch which detects that there is enough gas and if not the ac clutch won't engage.
这个答案有帮助吗?
I 've checked my system and there is no gas in it. How can I force the clutch to engage so I can recharge the circuit?
I don't have a answer but I have a mk2 ford focus my a/c clutch wont engage something to do witht he relay not switching?can some one help me please?btinto@hotmail.com
这个答案有帮助吗?
Sometimes due to wear your need to adjust the clutch on the compressor with shims. Most folks miss that and spend a small fortune trying re-gassing and replacing compressors.
这个答案有帮助吗?
what are the steps to adjusting compressor clutch
这个答案有帮助吗?
what adjustments are you looking for? What year is your vehicle and what engine size is it?
same problem here; I can get it going by pressing w a crowbar---but when I release the bar- no go
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 70
总计 29,285
