跳转到主内容
加入维修社区 - 创建账户
Motorola 于 2014 年 9 月 5 日发布的一款 Android Wear 智能手表。
Power Button is Broken
So out of no where my button stopped working, It no longer clicks. So it may just need realigned. Anyone else have that issues? If so, will Motorola cover it? Or did you fix it yourself? I did NOT get the Moto Care when I purchased the Moto 360, seeing as a run my own phone repair business, I figured there would be parts out there by the time I damaged it.
From what I can tell in the break down, the actual button is surface mounted and soldered on the board. As for the part of the button one presses, it's a little hard to tell.
Anyone who've attempted repairs on the Moto 360 have any suggestions?
Thanks! -Jeff
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
I have never attempted a repair on a Moto 360. However, I did have to deal with defective Samsung phones' power buttons which are also surface mounted on the board. Most of the times, cleaning with a good amount of 90%+ isopropyl alcohol (while staying clear of anything that could be ruined by IPA such as the screen) and a soft brush solved the issue. Worth a try. Let me know if by chance this helps!
这个答案有帮助吗?
得分 1
添加一条评论
Very late answer, but adding as i’ve just fixed the same issue.
You can actually remove the button, as it is glued on (from the outside) and then has a clip on the inside.
To do this you’d need to teardown the watch to it’s componants (follow this video https://www.youtube.com/watch?v=r1as_h5j...)
Once you’ve removed the clip on the inside of the button you can push it out, clean it throughly and then pop it back in, pop the clip back on and it should work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeff Caauwe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 55
总计 4,405
