跳转到主内容
加入维修社区 - 创建账户
Xbox One Kinect, Xbox One 随附的游戏外设。全球热销2300万台。
Remove cable from Kinect 2
My Kinect 2 on the Xbox One is faulty and has to be replaced. The cable is embedded and so I have to remove the cable from the head unit and install a new Kinect. My problem is that I can't find any guide that describes how to remove the cable. Advice and pictures are needed, please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论:
I pulled it out using force.
I would not recommend that way as of now because I have not managed to plug it back in as of now: How to best re-atach the cable?
由完成的
What do you mean by "cable is embedded" as in in a wall? And if so how did you get it there in the first place and why can't you just take it out???
由完成的
You need to disassemble the Kinect to get it back in, push it through the fan cage, I actually removed the shock gasket as well.
To remove, pair of pliers and pull.
由完成的
添加一条评论
4个答案
You need to disassemble the Kinect to get it back in, push it through the fan cage, I actually removed the shock gasket as well. To remove, pair of pliers and pull.
这个答案有帮助吗?
得分 0
添加一条评论
What would this cable be called? As I need a replacement? I know one side is a USB,B port, and I can't find a wire with the special Kinect side again..
这个答案有帮助吗?
得分 0
添加一条评论
I would love to know if there are shorter versions of this cable as well. That would make life so much easier!x
这个答案有帮助吗?
得分 0
1条评论:
Definitely looking for a shorter version also.
由完成的
添加一条评论
I found it quite easy to remove by twisting it, almost as if designed to be done so. If it is not designed that way, then at the very least the hard rubber flange extending above and below the connector will naturally force the connector to move forward or back if twisted in the rectangular slot where it resides.
This same physical feature made it somewhat more difficult to push back into the fully-assembled slot, but I found that starting at enough of an angle that allowed the hard rubber flange to bend backward, and then twisting into the proper orientation as you push inward, the result was a complete and solid connection.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
adriankamellard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 37
总计 6,510
