跳转到主内容
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
202 个问题 查看全部
Why is my kindle fire hd having sound but no picture?
My kindle fire HD has sound and I can hear noises coming out of my kindle. However my screen is showing no picture comeing through? How can I fix this as restarting is doing nothing to help my kindle fire?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
6条评论
i have same problem. did you find a solution?
完成的
i also have the same problem...did u find a solution yet
完成的
aaron81182 I was wondering if you got your issue fixed? Please see my reply about how I fixed it.
完成的
Mine just started doing this like 3 days ago and I CANNOT figure it out!
完成的
I did the 40 second hold on the power button and it worked
完成的
显示更多的1条评论
添加一条评论
7个答案
最有帮助的答案
I watched the you tube video. Held the power button for at least 40 seconds and screen came back!
这个答案有帮助吗?
得分 5
4条评论:
Wow...I was very skeptical but this worked!
完成的
Genius! Thankyou.
完成的
Unbelievable.....IT WORKED......THANK YOU
完成的
It worked, thanks so much for posting!
完成的
添加一条评论
katie, since you have nothing showing on your screen regardless of what you do, I would suggest that you use this guide. Check to make sure that your LCD is properly connected and that you do not see any obvious damage to the cable and any of the components on the board. It is possible that you have a bad LCD (or bad backlight), replace it and let us know what you find.
这个答案有帮助吗?
得分 3
添加一条评论
I had the same issue and Amazon was no help. I had to take the back cover off and unhook the battery. Next you re-hook the battery and the kindle started working. I had to re-set everything-clock, wifi, etc... but at least it's working.
这个答案有帮助吗?
得分 3
1条评论:
This is what helped with the issue mine had.
完成的
添加一条评论
Tried all the above, unconnecting and reconnecting the battery, holding down the power button, nothing works, the light is coming on the screen but there are no images, my son put it to charge and that happened.
这个答案有帮助吗?
得分 2
添加一条评论
My kindle fire has sound the screen is black. I’ve also un-hooked the battery several times. Thought I had it on the first try, nope. I have a full charge on it cause the screen comes on for a spilt second then goes back to black. Tired holding the power button for 20, 30, 40,50 seconds still doesn’t give me a functioning screen. About ready to call it quits. This happen about 4yrs ago and thought just maybe nope still doesn’t work.
这个答案有帮助吗?
得分 1
添加一条评论
my amazon tablet is not working but it just making sound but no pictures can you help me fix it
这个答案有帮助吗?
得分 1
添加一条评论
Mind is the relevant get my back of
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
katie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 92
总计 21,758
