跳转到主内容
加入维修社区 - 创建账户
Released in late 2012, the Asus X55C is a 15-inch laptop with a screen resolution of 1366x768. It has an Intel processor inside and uses Intel's integrated graphics.
Laptop Screen shows Pink/Green Horizontal Lines at the bottom.
I have no idea how did this happen.
I left it on while I was sleeping and when I woke up in the morning, it already has these pink lines (when on white background) or green lines (when on black background).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 23
8条评论
My Macbook pro just did this problem this morning ,but after coming home from school I took the risk of slapping the back of the screen near where the little apple sign is and when I did the pink and green lines disappeared.
完成的
It may come back. I recommend you ask a new question https://www.ifixit.com/Answers/Ask
完成的
@Prime Noscope67 your solution worked for me
完成的
It's the indication that your system is corrupted
完成的
I don't believe your system is corrupted. It's more than likely a loose wire joining the computer parts to the screen. I've seen it go away , temporarily, when the strip next to the side of the screen is pressed. But for a more permanent fix you may need to dismantle the plastic round the screen to get at the loose connection.
完成的
显示更多的3条评论
添加一条评论
19个答案
已选择的解决方案
Aju krishna, could be the LCD panel or the GPU. Connect an external monitor. If that show a good picture you know it is most likely your LCD panel that needs replacing. If the external monitor is showing the same issues, you have having problems with the GPU on the logic board and will have to at least disassemble your laptop to inspect. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
添加一条评论
最有帮助的答案
place your thumbs on the top corners of the screen and your fingers on the laptop cover. Gradually apply pressure with your thumbs until the colour is correct. This happens to my laptop every summer.
这个答案有帮助吗?
得分 20
22条评论:
"place your thumbs.......", I laughed when I read that but then I tried it. It didn't work with thumbs at top of screen but then I made my way down the sides of the screen and when I got to the top of the pink area and pressed with my thumbs the screen magically returned to normal. So I conclude that a lot of these problems are definitely caused by loose connector cables between the laptop and the LCD screen.
完成的
dude it worked you saved my life i love you (no homo)
完成的
OMG.. even I laughed at this solution but it worked ... Thank you so much..
完成的
Can somebody show how to do it via some video and provide the link here
完成的
Thank you!! The line was still present after I pressed on it but after a few secs it returned to normal.
完成的
显示更多的17条评论
添加一条评论
It's the connector cable from the laptop to the LCD screen that isn't connected properly.
If you take the screen surround off and then reconnect the screen cable and make sure it is fastened secure, this will get rid of the pink and/or green lines.
这个答案有帮助吗?
得分 7
4条评论:
how exactly??
完成的
i have only one green vertical line on my right side of the screen laptop
how? the pressing of top corners didnt worked for me :(
完成的
Same here like cenyom, except it's a pink line... How to fix it??
完成的
It's working, Thank you for the solution :) LOL...
完成的
添加一条评论
This has occurred with my laptop too...for 2 consecutive years; however, since I live in a part of the world where seasons change dramatically from exceedingly hot summers to exceedingly cold winters, I noticed that the morning pink and green lines only appear in the winter when temperatures go down to sub freezing. So, simple remedy: I now wrap my laptop in a blanket, or put it in an insulated bag before I go to bed, then, abracadabra, when I open it up in the morning, there are no green/pink horizontal lines!!!
这个答案有帮助吗?
得分 2
2条评论:
WTH??? Come to think of it it was really hot today and in the evening it rained and the temp went down and just then the screen went all pink and green lines... And I seriously thought i messed something up??/ But does temp really affect this much.. btw I am still typing this on a pink screen in search of a permanent fix...will be grateful if someone can help
完成的
Do you also feed some tea to the laptop? If yes, what kind of tea please? With or without milk? Please cause is important to keep the laptop happy
完成的
添加一条评论
The video was unavailable .
If someone knows something that can be done , ls let me know . The pink lines are getting larger ,thanks
这个答案有帮助吗?
得分 2
添加一条评论
Thank you
这个答案有帮助吗?
得分 1
1条评论:
i hate asus laptop so many problems
完成的
添加一条评论
Ohooo.... My God plz help me frds.... Bcz 'am also getting same. Pink and green line in the laptop screen and the bottom side of screen is blinking non- stop... , frequently...It is teriable for me...
Plz give solution.
这个答案有帮助吗?
得分 1
添加一条评论
May be its because of your Graphics Driver . There is a case of getting this issue when we use Huge Graphics Softwares Which our system Can't run Can cause this Trouble. I suggest you to Install a new graphics driver
这个答案有帮助吗?
得分 1
1条评论:
Yes I think this too as when I closed gta 4 which was sticking very much so the screen was turned green and pink from that moment when I closed gta 4.....
完成的
添加一条评论
This is due to several problems :-
  1. Operating System (Drivers)
  2. Hardware Problem.
To clarify just boot into BIOS of your laptop and see is lines still present ?
If lines disappear than your graphics drivers fault or that chip is damage.
If lines still shown in BIOS than your screen got damage. Just replace it.
这个答案有帮助吗?
得分 1
1条评论:
Right, but how do I "boot into" BIOS?
完成的
添加一条评论
on desktop > press right on mouse > screen resolution > change resolution to 800 (apply-revert)> change to 1200 (apply-revert) > change to 1300 (apply-revert) > change to preferred resolution back. Thank me by pray for me so that I’ll be very rich in near future
这个答案有帮助吗?
得分 1
1条评论:
Waw... this actually worked! Thank you, so much. I tried everything and this is the only thing that made a difference. I recently upgraded from Win 10 to Win 11 on my HP laptop and left laptop on longer than usual after falling asleep and woke up to find pink and green lines just like the other users along with an annoying flickering screen. This is a real fix. I totally recommend using this.
完成的
添加一条评论
this video i sthe solution for pink lines on laptop screen.it worked for me.
https://www.youtube.com/watch?v=4vUKudoF...
这个答案有帮助吗?
得分 0
2条评论:
Video Unavailable
完成的
video is not available
完成的
添加一条评论
i have pink line (up and down)and i just got the laptop its a chromebook plus (samsung)please if someone knows anything help me fix this .
这个答案有帮助吗?
得分 0
添加一条评论
I have the pink ( white board) & green (black board) on my laptop. Everytime I leave it on the lines get thicker. Any others ways to remove it rather than changing the screen ??
这个答案有帮助吗?
得分 0
添加一条评论
first restart the pc and then, hold the screen with your thumbs and press it there where is the line seen. if not worked yet the continuously try it. it worked on my pc really….
这个答案有帮助吗?
得分 0
添加一条评论
This happens with my laptop sometimes, when it was happening again just now I tried pressing fn + f7 twice which on my laptop normally turns the screen off and then back on, and it stopped.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
Weird enough this got fixed when I turned on the night light. I thought night light filters the pink and green light and somehow make them unnoticeable. But that turned out be not the case. Even after turning off the night light, the fix remains intact until I restart the laptop.
这个答案有帮助吗?
得分 0
添加一条评论
https://howtofixgadgets.com/horizontal-l...
This may help you in solving my problem. Try using a different monitor if that will be OK then it's the problem with your display if it shows any problem then there maybe any software issue or any other hardware problem.
这个答案有帮助吗?
得分 0
添加一条评论
it's happen in my laptop every time when i carry it in the airplane, it seams that related to temperature or to the atmospheric pressure.
but it disappere after time, while running the machine, i tryed to stroke it by thumbs, It gets good result sometimes.
but really it's weird, hope to know the root cause and the solution
这个答案有帮助吗?
得分 0
添加一条评论
I have pink and green lines going across my ASUS PC screen (horizontally) when it started it was just 5 and now there is about 35, they are green and pink on a black bg and get pale while on a white bg...sometimes they do not seem to show on white but are a faint blue color...when I adjust my volume, there is like a shadow line following the volume thing going vertical (sorry, lol, I do not know how to explain this, I am an empty head when it comes to tech)
这个答案有帮助吗?
得分 0
1条评论:
is it fixed now? and how did you fixed it. My lappy's condition right now is similar to yours. Where in I left it to sleep without the fan below. And now for the 2nd time it's having its meltdown and I'm having mine too (⁠╯⁠︵⁠╰⁠,⁠) does this occur to everyone who owns ASUS?
完成的
添加一条评论
添加你的答案
Aju krishna 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 44
过去 30 天: 191
总计 179,021
