跳转到主内容
加入维修社区 - 创建账户
Vizio LED、LCD、高清电视及其他电视产品的维修指南和支持。
horizontal line across screen.
Vizio E5001 HDTV. Picture has horizontal line across screen. Lower screen appears to be slightly out of focus. Narrow strip across top of screen looks to be bottom of picture.
Is this an adjustment problem of hardware issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 14
5条评论
Could be TAB (would most likely require a new LCD) as well as a t-con board issue. Post an image with your question so we can see what you see.
由完成的
I have 2 Vizo Tvs Both went out in 2 years period . I would love y
Too have them fixed but paid a lot for them 65in and a 45in Went back too store to see what kind of Warrenty they had none ...and 2 years and Over 2,000 Gone...
由完成的
I insured my Vizio E-series 50 inch 3D TV for $8. When mine went, They replaced my TV with a Samsung HDTV. There were NO Vizio 3D TVs available, and other 3D TVs were $1800 dollars MORE for 3D. They said: "You can do whatever you want with the broken TV. I kept it. I have now done all the research, and have purchased the necessary parts. I will now FIX that puppy.
由完成的
Just got a Vizio 55" smart tv have had it less then a week and lines through the picture when using YouTube. They stay even when I back out to regular tv and have to shut off tv to get rid if them.
由完成的
I'm having a similar issue with a vizio sv470m. When I go to turn it on, the tv will have horizontal lines. Eventually it ends up working correctly. I just play with the buttons or unplug the power for certain amounts of time. After I get the tv working, as long as its on there are no issues with it whatsoever. Now if these simple methods don't work, ive heard it may be issue with the ribbon that connects between the board to the screen and the other board. I'm not being specific because on my model it look like the display board goes to the power board. I'm guessing its both the tcon and power board.
由完成的
添加一条评论
14个答案
最有帮助的答案
Wow these are some misleading amature Repair answer on this forum. Unless you are a certified tech or have many years actaully Repairs not replacing parts, shouldn't answer. I do motherboard work and I've never had a tv issue that isn't fixable . the only way I've ever replaced the whole LCD Screen itself is if it's completly shattered. I then still pull it apart , =Repair any damages backlights , resolder chips, replace ribbions and etc. Finding a compatible front glass of the layers of the screen can get tricky but it's all just a matter of proper research , self confidence and dedication. If not tech savy with a solder gun or ever messed with a board have a tech savvy buddy lend a ✋ . ///dpluda563@***gmail///.\\\com\\\ all one word no symbols I use to avoid spam . need help feel free to message I'll do best to lead you in the right direction.
这个答案有帮助吗?
得分 2
2条评论:
I'm in need of some help what's the steps and binding compatible LED screen for a Vizio e70 E3
由完成的
My TV has several horizontal lines and the picture struggles to come into focus , but I've found that it's only when tv is cold. Something has warped a bit from being on constantly for thousands of hours. After 5 or so minutes it warms up and picture is fine. You can actually see it getting better as time progresses. If this happens when you turn it on, wait a half hour and see. I just keep it on constantly but when theres a storm and power fails for more than 30 minutes or I forget to turn it back on after, only time it happens. Actually waiting for it now.
Same issue here, multi colored blurry image on start up, then settles down after ‘warm up’ approx 5 minutes.
What part needs replacing?
由完成的
添加一条评论
If it's a t-con issue, you could order the part from http://vizpartsdirect.com/index1.php and install it yourself to save some money.
Here is the link to their parts sections: http://vizpartsdirect.com/parts.php?belo...
这个答案有帮助吗?
得分 0
11条评论:
I have a similar problem it's not a black horizontal line but a darker color line then the rest of picture. I will take picture when I get home and send it.
由完成的
I have a Vizio LED TV 70" Model: M701d-A3
There is a single horizontal line across the screen that shows up in the lower aspect of the screen, extending more than 3/4 of the screen width. The line is black in color, you can see it with all TV inputs and when you pull up the menu it appears over the Menu.
How can I fix it?
由完成的
I have a 42" vizio smart tv and the black horizontal line appears for 2 seconds...then picture gets blurry for 2 seconds..then it keeps repeating itself
由完成的
I have the same issue as Nate. Any fix? Can't afford new TV.
由完成的
I have a 19" vizio and it has a green line across the bottom and it constantly flickering, i have no blurring though, still great picture just the line at very bottom that won't go away. Anybody else experiencing this.
由完成的
显示更多的6条评论
添加一条评论
Try switching to a different outlet. I had mine connected to a bad power conditioner (Isobar) box. After I plugged it into a different outlet, it works fine now.
这个答案有帮助吗?
得分 0
添加一条评论
The top of the screen is turning dark. About 6" down from top down. Visio 65" smart.
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
1条评论:
Same issue what part needs replacing?
由完成的
添加一条评论
hi thats seems to be a screen malfuction, the only possible repair is by changing the screen, i had seen this problem a lot on laptops displays and pc monitors, good luck
这个答案有帮助吗?
得分 0
添加一条评论
'''Got a 24” smart tv D24f-F1 model. Got a blackscreen with blurry vertical lines. the only part of the screen that is still visible is the very top of the screen. If i leave it on for several hours sometimes it comes back to focus but i have been curently waiting an hour an 45 minutes for it to come back and still nothing. Any suggestions? I have tried a power cycle with no results and was told to factory reset but cant see the menu :(
这个答案有帮助吗?
得分 0
1条评论:
[image|1650343] i unpluged it and moved it to a different outlet. It cleared the screen up enough to let me factory reset it. But now there is a black horizontal line across the botom of the screen
由完成的
添加一条评论
I have a vizio e65 3c. I'm having horizontal lines on picture that roll from bottom to top. As if the vhold is off on an old school tv. Screen is not broken. All backlights work and replaced tcon and main board. Still having same problem. Please help. Please email me with help. Jakebraswell1328@gmail.com
这个答案有帮助吗?
得分 0
添加一条评论
I ended up taking it back and exchanging for a new one same model. After a week I was having the same issues so I took it back again and got a Hisense. I have not had a single issue with the Hisense.
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem with lines then dots running horizontally across the middle of the screen. Went to reset and it solved the problem.
这个答案有帮助吗?
得分 0
添加一条评论
That wasn't the solution to my problem. Someone had posted a while back, that it was a resistor or something that they had to change out.
这个答案有帮助吗?
得分 0
添加一条评论
Yes I have this problem
这个答案有帮助吗?
得分 0
1条评论:
I need to know what's wrong with my tv
由完成的
添加一条评论
If it is an LG or Mitsubishi (supposedly respectable brands) or Westinghouse, Element, etc (the ones placed in displays in the middle of the aisles at most Walmart’s), my recommendation is a 12-gauge Winchester slug to the center.
这个答案有帮助吗?
得分 0
添加一条评论
I have a Vizio plasma screen 40 in it has a green line 9 inches long down the top left edge of the screen down how do I get rid of that ? Maybe have it serviced thanks a
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
silentservice650 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 20
总计 92,571
