跳转到主内容
20", 23", 和 30" LCD 显示器 发售于2004 于 2010年停产。
99 个问题 查看全部
vertical yellow line on my Apple Cinema HD Display
A faint vertical yellow line has appeared on my Apple Cinema HD Display. I do not want to replace the monitor if possible. Are there any ways to fix this?
thanks,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Post an image of what your monitor displays. That way we can see what you see.
完成的
I tried taking a screen capture of the line, but when I do, it does not show in the capture, which is kind of bizarre.
完成的
If a screenshot shows the problem, the problem is with your computer (most commonly the video card). If a screenshot does not show the problem, the problem is with your monitor. So it's not bizarre at all although I can understand why you'd think so. Take a picture with a hand-held camera, that will allow the people here to see your issue.
Yes, I know this is more than 5 years late. Sorry, I was busy in the Andromeda Galaxy and just got back.
完成的
添加一条评论
2个答案
已选择的解决方案
Barb, not really. Those things are hard to photograph:-) If it is a single line from top to bottom it is most likely a TAB error and 'can not be fixed. You will either have to live with it for a while or replace the panel.
这个答案有帮助吗?
得分 1
2条评论:
OK, turned on the computer today and yellow line has disappeared....what does that mean...
完成的
Loose TAB can cause it as well as loose display cable (unlikely) if it stays normal, consider yourself lucky and it may have just been a fluke :-))
完成的
添加一条评论
Connect your computer to a different monitor and if you see pretty much the same thing in the same place it's the GPU/VGC of the computer - if you don't it's a problem in the Cinema display panel.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 0
1条评论:
I will try this tomorrow and let you know what happens...
完成的
添加一条评论
添加你的答案
Barb 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 1,512
