跳转到主内容
加入维修社区 - 创建账户
Galaxy Mega 发布于 2013 年 6 月,是一款配备 6.3 英寸 720P 显示屏、双核处理器和 800 万像素摄像头的智能手机。
Samsung Mega Black Screen
I recently installed my replacement LCD digitizer for my Samsung Mega. Upon installing it the first time, the screen came on and I could see everything but would not respond to touch. I removed the back and the flex cables and reconnected them, now when I turn the phone on the screen is black but I can hear the phone turning on. Could you possibly tell me what may be wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Thank you for the advice, I will contact the person I purchased it form.
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi Brittany
Its possible the connector is not seated all the way and is causing your issue, Check that first.
If that does not solve your problem, its possible that screen has accidentally been damaged. I would test the device with another known working screen, if it works, then yeah the display is bad. If it does not work and its a known working display your testing it with. Then its the motherboard of the device that is not outputting a display and not the screen itself.
But like I said, its possible the new screen went bad. They can be easily damaged during the install process. Also by bending one of the cables to much could have caused damage.
Hope this helps in solving your issue.
V/R
Josh.O
这个答案有帮助吗?
得分 1
1条评论:
I agree with Josh This has helped me in the past.
由完成的
添加一条评论
添加你的答案
Brittany 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 29
总计 4,273
