跳转到主内容
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
My device will not go on and wont charge
My device will not go on and does not show any sign of life even when cinnected to its charger was working ok till thus morning
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
1个答案
最有帮助的答案
graeme, check the charging port and make sure it is not bend or has any debris in it. You can clean it with a few puffs of air and some isopropyl alcohol. Make sure that you charger is working properly. Use a multimeter and see what it puts out. After that, you may have to open up your Galaxy and change the battery.
这个答案有帮助吗?
得分 4
2条评论:
new battery and still won't charge, even losing charge overnight while plugged in. tried different outlets, no help. battery runs out while plugged in! what is going on?
完成的
I have seen this due to malware. Try TrendMicro to clean-up your device, if/when you get it to turn on. I've used them for years.
完成的
添加一条评论
添加你的答案
graeme 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,969
