跳转到主内容
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
121 个问题 查看全部
Blinking green light after power outage on Mitsubishi WS-55511 TV?
My TV won't turn on after a power outage. I just have a blinking green light.
Will the fix described for "Repairing Mitsubishi WS-65511 Blinking green light" work on my older model?
Do I use the same 1000uf 16 volt capacitors that answer indicated? Where do I buy them since Mitsubishi doesn't have them on their parts list?
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Jeanie Kansas, yes I would suggest that you replace the caps. You can get those from compnaies like Mouser.com or Digikey. com as well as many others. the blinking green light can also be caused by the DM module's EEprom is intermittently bad.
这个答案有帮助吗?
得分 1
添加一条评论
Hi,your tv needs the dm power board repaired,we do this repair from e b,ay.search for listing #330700000004.on main search bar.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeanie Kansas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 534
