跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Why is my keyboard acting so strangely?
Hi all,
I'm having a very odd problem with my keyboard on my Macbook Pro Retina Early 2013.
The best way I can describe the problem is that a bulk majority of the keys do not work or respond. However, after giving the computer 5-10 minutes the keys gradually become completely functional. While there are some letters/glyphs that occasionally give me trouble during the first few minutes, they are not confined to a certain area within the keyboard and the problematic keys are never the same.
Any thoughts what could be going on? There's been no accidental damage to the machine and unfortunately I'm about three months out of warranty. Any thoughts on why it might be doing this? It's quite strange.
To give a better idea of the problem, here is an image of me trying to type the same few short sentences over and over again while the computer begins to work again. First sentence is the sentence I'm typing, free of errors.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I suspect the battery is swelling causing pressure from below.
I would bring the system into an Apple store as they did have a recall on some systems due to a bad set of batteries.
这个答案有帮助吗?
得分 1
2条评论:
Thanks Dan, I'll give this a shot. Just seems so odd that it gets better as I type more and more.
完成的
The pressure will change as you use the system as the chemical reaction will re-absorb the gas.
完成的
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 208
