跳转到主内容
加入维修社区 - 创建账户
Samsung 数码相机的维修指南和技术支持。
lens open & close same time
My samsung camera DV 150F as soon as i press the power button LENS opens & close same time and follow message appears on screenTHE ZOOM DIDNT OPERATE NORMALLY INSERT THE BATTERY AGAIN AND TURN THE CAMERA ON IF NOT WORK CONTACT THE SERVICE CENTRE.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 17
添加一条评论
3个答案
已选择的解决方案
Raza, first of course you want to follow the instructions given to you regarding the battery. If that does not work, it sounds like you are having issues with your lens not properly extending. You could try and clean it, check to see if it looks center when retracted. Check on here for more information.
这个答案有帮助吗?
得分 3
添加一条评论
I tried the paper shim going around between two lenses and body and lens, compressed air, allowing small amount of alcohol on q-tip on gap - and nothing would get my lens to open. Then I held in flat between my two hands and "gently" gave it a very light twisting diagonally, once in each direction. Hit the power button and it works fine now. As my gaffer used to say, "Don't force it! Get a bigger hammer!"
这个答案有帮助吗?
得分 2
添加一条评论
Try removing the battery exactly as the lens comes out.. it worked for me while all the other solutions failed.
这个答案有帮助吗?
得分 1
1条评论:
You saved my life, thanks a lot :)
由完成的
添加一条评论
添加你的答案
Raza 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 43
总计 12,165
