跳转到主内容
加入维修社区 - 创建账户
2.0 GHz、2.3 GHz 或 2.6 GHz 四核 Intel Core i7 处理器(Turbo Boost 最高可达 3.8 GHz),配备 6 MB 共享三级缓存。
Can you replace the battery
Is the battery replaceable over the life of the macbook or are you out of luck when the battery life degrades past a usable amount.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
Good question!
For some reason Apple decided to glue the battery cells to the top case in this system.
Apple does not sell the battery pack alone only as part of the top case assembly (P/N 661-6532) which is quite expensive! (around: $180 used & $600 new).
There are a few dealers of the battery unit alone. As reference: LaptopBatteryExpress for around $130.
If you do try swapping the battery be very careful! Make sure the battery is discharged, use a adjustable temp heat gun to soften the glue, a set of plastic spatulas and lastly have a chemical fire extinguisher handy! You may need it if you pierce a cell.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
I got one of these in this week with a wine spill. An uppercase replacement part priced out at around $700. I took a hypodermic syringe and filled it with methanol and shot about 3 cc of it around each of the batteries. Let it sit for 10 minutes and rocked it a few times to get the alcohol as deep as possible. Then I used a putty knife. I inserted it on the outside batteries first from the side closest to the keyboard. As each battery came up I laid it back. It took less than 5 minutes to have the battery out and in good shape. Looks like prices run from $75 to over $150 for replacement batteries. On mine I needed to replace the keyboard but that's another story. I found a new part in China with keyboard for $158. I'll end up with a new upper case replacement and save $525 making the repair feasible. New trackpads are also available on eBay.
这个答案有帮助吗?
得分 4
7条评论:
@Mayer - I hope you blow out the methanol before pulling at the battery. Remember methanol is flammable! You don't want to give the fire extra fuel. But it does sound like a better way than trying to heat them up hot enough to get the glue to let loose. Just be careful ;-}
由完成的
Dan, the methanol had very little liquid residue as it evaporates very quickly and has no water in it like rubbing alcohol. When burning in something like an alcohol torch it doesn't sputter. It can be obtained at dental supply places. I did not know if it would work, thus I didn't take photos for a guide. But this method will make a lot of the newer machines repairable. The iFixit team took 30 minutes to get their battery out. Mine came out very clean and is totally reusable.
由完成的
Do you want to post something over in Meta so the IFIXIT gang sees it. Good tip! I don't currently have too many retina systems to work on here. But the next time I have one which I need to pull the battery I'll give this a go!
由完成的
I will do it.
由完成的
Thank you for this, this was very helpful information.
由完成的
显示更多的2条评论
添加一条评论
Some nylon string, sprinkled with a generous amount of caution, will do the trick.
Once I removed the right speaker, it only took me 10 minutes to cut the glue holding the batteries.
It is very doable if one proceeds with caution.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Munish Gandevia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 2,856
