跳转到主内容
加入维修社区 - 创建账户
Cyber-shot 系列中的一款卡片相机,发布于 2010 年。
cybershot dsc-w310 is showing only white screen
it is showing a white screen when it is turning on
and no change for further
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
7条评论
any answer for this? I also got white screen everytime i turn on the cam.
完成的
Push down all the buttons at once and push and hold the on -off button until it resets and the white screen should disappear .
It took me a few times,as it's a bit awkward.
完成的
I get a white screen when I take a picture, almost everytime, the odd time it doesn't?
完成的
I see the image fine through the screen but when I take a picture, it comes across as almost all white (slight horizontal shading).
How does the reset work? Which buttons should be held down? all of the menu and display buttons on the back?
完成的
If the almost white screen (we call wash out) only happens for pictures then the issue is your lens or settings. Go to main menu/settings/initialize settings. If that doesn't work then you will need a lens replacement because you have a bad iris/aperture.
Question are the lines slightly bent? Do you have any heavy hues like purplish.. etc.. in your picture or is it just washed out?
完成的
显示更多的2条评论
添加一条评论
1个答案
最有帮助的答案
Sounds like either moisture damage, a loose or bad lcd or bad board. If you are up to it open up the unit and
reseat the LCD back into the ziff clamp and see if that helps. There is a clamp that holds the LCD down and
it may have come loose. Try to reseat the LCD, and while you have the LCD disengaged examine the flex
cable for damage. Keep us posted. If you need a disassembly guide just let me know.
这个答案有帮助吗?
得分 2
1条评论:
How do you know how to open the camera?
完成的
添加一条评论
添加你的答案
praveen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 21
总计 5,937
