跳转到主内容
The 2008 Nerf N-Strike Recon CS-6 is a customizable, manual, clip-fed dart blaster sold by Hasbro.
How do I remove the magazine?
Instructions for removing the magazine from the gun.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
10个答案
最有帮助的答案
To remove the magazine there are two buttons located on each side of the gun. Use both hands to pull back both buttons at the same time, and then the magazine should simply fall out.
这个答案有帮助吗?
得分 5
2条评论:
yeah bro its easy
完成的
Which side are the buttons on
完成的
添加一条评论
Yellow model: Pull the grey slide mechanism back. Open the black hatch. Push down on the magazine while sliding the two orange unlock buttons.
这个答案有帮助吗?
得分 4
2条评论:
works for recon mkII as well
完成的
This is the answer I was looking for! Thank you! Just pulling the release buttons did not work
完成的
添加一条评论
Pull the slide back and pull the orange release next to the magazine
这个答案有帮助吗?
得分 2
添加一条评论
How do I remove the magazine if the slider is broken and cannot slide back?
这个答案有帮助吗?
得分 1
3条评论:
Try firing the gun
完成的
smash it on your sofa like a madman
完成的
If the cover of the sliding mechanism comes off, use a long thin screwdriver and push it through the holes in the long slits, and then pull that back. If the slide wont pull back, try firing the gun and then pulling back. If that doesn't work, open up the blaster (please record what you're doing it as you're doing it in case you cant easily re assemble it) and try and see if its jammed.
完成的
添加一条评论
I have placed my darts of my recon cs-6 accidentally but i cannot open it because it is too hard i cant use the opener
这个答案有帮助吗?
得分 1
1条评论:
:o its jammmedso hard?
完成的
添加一条评论
https://www.youtube.com/watch?v=pU5waRnk... Watch this and see
这个答案有帮助吗?
得分 0
添加一条评论
The orange button near the trigger will release the magazine
这个答案有帮助吗?
得分 0
添加一条评论
my slider is broken and i cant release the magazine
这个答案有帮助吗?
得分 0
1条评论:
me either it is soooo jammed that i am poop
完成的
添加一条评论
You have to pull the reloading trigger on the top and push the button on one. the pusher)
Then take out the mag.
这个答案有帮助吗?
得分 0
添加一条评论
My magazine won't come out of the
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Asad Qureshi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 50
总计 35,006
