跳转到主内容
加入维修社区 - 创建账户
The Roomba 650 is a Fourth Generation robotic vacuum released by iRobot in August 2012. This device is hand-free and is programmed to clean our homes. With little manual operation needed, this robot have revolutionized house cleaning.
Resistance in right wheel/"error 5"
I've been getting the "Error 5 right" message on my Roomba 650. The right wheel seems to have twice the resistance of the left wheel. I took out the wheel module, opened it up and cleaned everything out. The problem persisted so I ordered a new wheel module. Still no luck. Then I noticed something very odd: the wheel has normal resistance when it's out of the Roomba but as soon as I lower it into place the resistance immediately doubles. Even with the battery removed this happens. I've very meticulously cleaned out the wheel well and it makes no difference. I've also cleaned the optical sensors and tried doing the Spot/Dock reset. Nothing. Any ideas??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
15条评论
I have the same exact problem
完成的
I also have this problem- did you ever figure it out?
完成的
Any of you guys had any luck? I have the exact same problem
完成的
I called them about it and they said I need a new robot. They will sell you just the robot part for $199 and you use your own charger & battery and maybe a couple of the other parts
完成的
I had same problem and ordered a new wheel - still same problem. they offered to sell me the core unit for 20% off - which they said would cost around $330. I declined and returning part. We haven't used it on a daily bases so would have thought it would last longer than a year or so. :-(
完成的
显示更多的10条评论
添加一条评论
4个答案
最有帮助的答案
This is what is known as an H-Bridge driver circuit problem. It is an issue on the main circuit board. It can be fixed but only by somebody with advanced circuit repair knowledge. Replacement of the main circuit board is what I do to fix them. While relatively complex, it isn’t outside the realm of a reasonably competent DIYer. Of you can send your bot to a robot repair company. Boards are available on EBay.
这个答案有帮助吗?
得分 2
添加一条评论
If you notice that the wheel turns freely when removed, but immediately has resistance when installed then this is an issue with the computer circuit. Possibly it got wet, and a line on the board shorted it out. if replacing the wheel module did not fix the issue, then you need to get a new computer circuit board. unfortunately, the last I checked you can’t buy the circuit board separately, but have to buy a whole new roomba minus the battery. last I checked they were selling the roomba sans battery for about $500. if you are lucky you might be able to find a board on ebay or some other outlet.
这个答案有帮助吗?
得分 1
添加一条评论
I believe it is a loose connection of solder point near the plug. I used electric cleaner from radio shack and it worked again for a few seconds and then stopped. Need to figure out how to get into this area of the Roomba. Watching Youtube for the answer. Looks like the area is plastic welded shut. Either way I'll get inside for a visual inspection.
这个答案有帮助吗?
得分 0
添加一条评论
I ahve tried everything for error 5 on roomba 805. Took all wheels or cleaned and reset battery … The wheel runs perfect out of the housing once in lock up again. How can I resolve this
Aaron Marquez / aaron.sleep@gmail.com
这个答案有帮助吗?
得分 0
1条评论:
hey there i think this i roomba thing, cus when i had roomba it had kinda same problem, and this problem appeared and reappeared from time to time, i mean i had many vacuums for example vacum which i bought from these guys https://www.instagram.com/bobsweep/ was good and without this problem
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 43
总计 14,553
