跳转到主内容
加入维修社区 - 创建账户
2013 年 9 月发布,型号为 T100T。这是一款二合一便携设备,搭载英特尔® Atom™ 四核处理器和 2GB 内存。
Replacing of hard drive
Location, replacement, and largest size that can be on tablet on the Asus Transformer T100
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
6个答案
已选择的解决方案
You cannot replace the "hard drive" because it doesn't have one. It has an integrated chip that's solid state. What you can do though, is use a micro sd, and get a OTG (on the go) connector for your micro usb, and connect tons of usb thumbdrive sticks to it, or an external HDD.
这个答案有帮助吗?
得分 4
3条评论:
What if your hard drive is working correctly and the administrator is not functioning
由完成的
The tablet itself does not have a hard drive. But the detachable keyboard absolutely DOES have a hdd unit.....
由完成的
I have two of these T100 and neither have a hard drive in the keyboard.. both stuck in bios. When i tried booting the drive it gets error )xc0000001.
由完成的
添加一条评论
Dustin is correct for most Asus T100. But Asus does produce a version with a 500GB hard drive installed in the keyboard unit. The standard unit, without the hard drive, is likely a T100TAM-C1. The unit with an installed 500GB drive is a T100TAM-H2.
I am not 100% sure, but I believe all keyboards are wired for the hard drive, regardless if one is installed, or not. So a hard drive can be added to a unit after purchase.
这个答案有帮助吗?
得分 1
2条评论:
Sorry, the ASUS Keyboard dock without an HD are too thin and lack the interface for a har drive.
由完成的
Those keyboards are only on the latest units, anything more than a year old does have an hdd installed. I am on my second of these, two different types and sizes, and they both had hdd's installed in their keyboard docks.
由完成的
添加一条评论
I believe that the keyboards are interchangeable.
这个答案有帮助吗?
得分 1
添加一条评论
I can assure you taht all of the keyboards are NOT the same. Mine does not have the space or the connectors to add a HDD.
这个答案有帮助吗?
得分 0
添加一条评论
Well, if it is a model with a hdd, here's a link as to how to replace it.
I was unfortunate enough to have the hdd in my t100ta fail, and this is how you take it out (or perhaps replace it)
这个答案有帮助吗?
得分 0
2条评论:
why you were unfortunate , it didnt work ?!!
由完成的
If a replacement keyboard says T100TAM-H2-GM, as mine does, another keyboard with the same number would not have a slot for a HDD?
由完成的
添加一条评论
The hard drive is located in the keyboard. My Asus Transformer book T100 has a hard drive problem and i found the location of it during the replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim Burnett 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 45
总计 25,658
