跳转到主内容
Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
80 个问题 查看全部
Replacing of hard drive
Location, replacement, and largest size that can be on tablet on the Asus Transformer T100
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
6个答案
已选择的解决方案
You cannot replace the "hard drive" because it doesn't have one. It has an integrated chip that's solid state. What you can do though, is use a micro sd, and get a OTG (on the go) connector for your micro usb, and connect tons of usb thumbdrive sticks to it, or an external HDD.
这个答案有帮助吗?
得分 4
3条评论:
What if your hard drive is working correctly and the administrator is not functioning
完成的
The tablet itself does not have a hard drive. But the detachable keyboard absolutely DOES have a hdd unit.....
完成的
I have two of these T100 and neither have a hard drive in the keyboard.. both stuck in bios. When i tried booting the drive it gets error )xc0000001.
完成的
添加一条评论
Dustin is correct for most Asus T100. But Asus does produce a version with a 500GB hard drive installed in the keyboard unit. The standard unit, without the hard drive, is likely a T100TAM-C1. The unit with an installed 500GB drive is a T100TAM-H2.
I am not 100% sure, but I believe all keyboards are wired for the hard drive, regardless if one is installed, or not. So a hard drive can be added to a unit after purchase.
这个答案有帮助吗?
得分 1
2条评论:
Sorry, the ASUS Keyboard dock without an HD are too thin and lack the interface for a har drive.
完成的
Those keyboards are only on the latest units, anything more than a year old does have an hdd installed. I am on my second of these, two different types and sizes, and they both had hdd's installed in their keyboard docks.
完成的
添加一条评论
I believe that the keyboards are interchangeable.
这个答案有帮助吗?
得分 1
添加一条评论
I can assure you taht all of the keyboards are NOT the same. Mine does not have the space or the connectors to add a HDD.
这个答案有帮助吗?
得分 0
添加一条评论
Well, if it is a model with a hdd, here's a link as to how to replace it.
I was unfortunate enough to have the hdd in my t100ta fail, and this is how you take it out (or perhaps replace it)
这个答案有帮助吗?
得分 0
2条评论:
why you were unfortunate , it didnt work ?!!
完成的
If a replacement keyboard says T100TAM-H2-GM, as mine does, another keyboard with the same number would not have a slot for a HDD?
完成的
添加一条评论
The hard drive is located in the keyboard. My Asus Transformer book T100 has a hard drive problem and i found the location of it during the replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim Burnett 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 15
过去 30 天: 46
总计 24,088
