跳转到主内容
加入维修社区 - 创建账户
型号 M2453 或 M6411 / 300、366 或 466 MHz G3 处理器
My screen went black
I bought a clamshell 300MHZ. The man I bought it from put 60GB hard Drive and 320MB Memory RAM,
with this specs, install on it OSX TIGER 10.4.11. Once I got it Started it up and all went well for about an hour. Then the screen went black and I cant get it to start up again.
Any Suggestions would be most appreciated I was going to use it for my Grooming business.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Ok I tried the command p-r-power start without the battery. It tried to start but didn't give me anymore than a small swirl sound then no more.
I am looking for the Panther 10.3 but unsure where to find it. going to look on e-bay.
由完成的
添加一条评论
3个答案
已选择的解决方案
According to Mactracker your computer will only go to OSX Panther 10.3.
I suspect your use of 10.4 may be the cause of your difficulty. If possible try booting with a system disk for 10.3 and if it goes well you may want to install 10.3. Good luck. Ralph
这个答案有帮助吗?
得分 2
1条评论:
+ requires System 8.6 or later, 10.3.x officially supported, 10.4.x can generally be installed using XpostFacto 4
由完成的
添加一条评论
If you do not have firewire
(1999) you could meet Processor, RAM, and HD Specs but still fail system requirements.
Take out the battery and unplug it. Do a command-p-r-power start and boot holding shift key down.
If it boots immediately go to the energy saver and set it not to go to sleep or put the display to sleep.
I think it's a "wake from sleep issue"...though IMnsHO actuality you'd be better off running only 10.3 (you're asking an awful lot of your old hardware running 10.4)
If this answer is acceptable please return and mark it.
Good Luck
N.
这个答案有帮助吗?
得分 1
添加一条评论
Its the onboard ram. When you turn the Ibook on press the reset button and then the laptop will restart. If the laptop just turns off then turn it back on again. this should solve you situation.
这个答案有帮助吗?
得分 0
1条评论:
@edizmustafa
hey could you tell me the solution my laptop turn on and when its about to get in its turn off and restart again as loop when I check for long I found it its from intel gpu when I turn it off its work like 70% I tried download windows again 10-11 nd same issue could anyone help
由完成的
添加一条评论
添加你的答案
Jacqueline Bales 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 2,256
