跳转到主内容
两轮电动交通工具,包括轻便摩托车和小型摩托车。
sumthin is pulling it back from goin faster!
TaoTao Thunder 50cc runs fine until it hits 30 mph then it feels likes sumthin is pulling it back from goin faster!!! Anyone got any help?? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
dadandnmd, you posted your question as an answer to a FA-50 question. I changed it since it obviously is not an answer. Anyhow, the FA50 has a high speed of 27-30mph. So your 30mph is correct. There is nothing holding it back other than the stock performance of the engine. A correctly adjusted carburetor and muffler cleaning are the two most important factors in reaching the stock speeds. It's a moped not a racing bike. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
5条评论:
Ok sorry about that...lol and thats not my bike.. I have a tao tao 50cc...
完成的
It seems like there are lots of those scooters around too:-) The high speed of those scooters is listed at 50kpH which again comes up as 30mph. I would think that these engines have some sort of governor to limit it to 30mph which is most likely what you feel. The reason for that is the licensing of those. If the manufacturer would make them go faster, then they go into a different class. For many countries that would mean a separate drivers license. Hope you have more information on your scooter other than that it has a 50cc engine.
完成的
Its a taotao thunder and it feels like its dragging when im going down hill... it use to go smooth down hill but now its not going its full speed down hill... hope this is better... thanks for trying to help cuzz I cant figure out wat it is....
完成的
ok , thank you but don't be a -- we all don't know everything
完成的
thank you ,just thought do more with what have ! don't get mad , watch you
完成的
添加一条评论
Mines does the same thing I don't know what it is I have a 2015 50cc thunder
这个答案有帮助吗?
得分 0
2条评论:
Have you found out anything more
完成的
There is a few things u can do to make it faster check you tube
完成的
添加一条评论
添加你的答案
dadandnmd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 2,470
