跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
YLOD Light Sequence Really Persistent
This is what i said to the IFIXIT staff and they recommended me to try the forums for some support from the public etc.
sorry to be a bother any help is of help.
I have followed the YLOD repair guide by MJ on the IFIXIT website and
the problem still persist's, the flashing red light is what remains
after this light sequence: Green,Yellow,Red Flashing, then i press the
power button again and it goes to a solid red light then i press it
again at the light sequence repeats i can hear the CPU Fan spin for
about 2 - 3 seconds then it cuts off i have my suspicion its the
motherboard :/ i have used Artic Thermal Paste 5 on both the CPU & GPU
and evenly spread it using the plastic card technique and followed the
PS3 disassembly guide from step 42 backwards to re-put everything back
together correctly please help me
Okay so i managed to do everything correctly like the video instructed the issue i get now is, the PS3 only stays on for about 3 minutes before the green,yellow,green,red flashing light sequence re-appears then when i press the power button again it just flashes red then goes a solid red so i press the power button again and it works for another 3 minutes. it only seems though to come on with the solid green light and blue light when i have used the heat gun for about 5 minutes.
can any one shed some light on my problem please >.< ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Jaysonbroome, first you do need to remember that this will only work if your YLOD is caused by solder fractures and if they are not to extreme. Reflowing any board with a heatgun is not an exact science and as such does have a certain amount of failure. The proper fix for this would most likely be a professional reball. Anyhow, the biggest reason for failure to reflow is not enough consistant heat. There is a fine line between reflowing and absolutely melting the solder, so one needs to be aggressive without going over board. If nothing else, get a couple of temperature probes and see what heat you generate. For a decent reflow you want to be between 225 and 235 degrees Celsius for about 90 seconds. You don't want to be above 217 degrees Celsius for longer than 3 minutes. Even a mediocre heat gun should accomplish that. You'll find a decent write up about a good procedure right here. Follow the guide from here and keep on trying. If at first you don't succeed....:). hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
It is possible the processors need reflowed with a reflow station. I warn all my customers that there will come a point in the life of the console that it is not repairable at my level (don't own a reflow station). Sometimes the board is too bad that a heat gun will not solve the ylod.
Additionally, if the ylod repair doesn't work the first time, I attempt it a second time. Give it a go again. Make sure you set your heat gun on high and get the target area good.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jaysonbroome 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 287
