跳转到主内容
How much thermal paste to apply?
I've recently fully stripped a water (coffee) damaged MBP to give it a good clean (including removing the thermal paste).
Now im in the rebuild stage and come stuck regarding the replacement of the thermal paste. Basically, how much do i need to apply on each of the chips?
Because when i removed the logic board, the paste had overflowed in different amounts over the chips on to the green circuit board.
The reason i ask, i remember when my had to replace the thermal paste on my old PS3, too much paste was considered just as bad as too little. Is that the case here?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
taff, just to much would be just as bad since it would block the heat transfer. Anyhow, take a look at this great guide. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
5条评论:
Thanks oldturkey03 for your quick reply.
I did view the guide that you linked before I posted this question. In hope that it would answer my question. But unfortunetly, it only states to apply the paste with your finger and it doesn't give the amount to apply :(
完成的
Yes, I see what you are saying. Since most of us on here use a lot of Arctic Silver thermal paste, I recommend using the instructions posted by them on here. The instructions should also hold true for other manufacturers. Hope this helps, good luck.
完成的
Thanks for the new link. After a bit of searching, I managed to find the right page.
I've just had a thought. What if I put a dollop of paste in the centre of each chip, then when I place the logic board back on and secure it, will that not spread the paste to the correct thickness?
完成的
Yes it will. A bit of paste the size of a pea should do
完成的
Excellent...thanks
完成的
添加一条评论
添加你的答案
taff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 849
