跳转到主内容
加入维修社区 - 创建账户
Compaq CQ57 系列笔记本电脑的支持信息。
Computer will turn on, screen won't.
My computer will turn on, and it'll give me a couple seconds to go to the start up menu, but beyond that the computer screen stays blank. When I try the options on the start up menu it will just turn the computer screen blank. I've tried the removing battery and holding the power button. But that hasn't changed anything. I don't have the material to connect to another screen, let alone know how to do so.
My friend thinks it has something to do with a virus. I gave her my computer to try to fix and she said she found 9 trojans and several other minor viruses. It's a used computer and I can't afford a new one.
Any help is appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
So its now just turning on and off, the screen. The computer is still running, but it'll spend like 3 seconds on the orange screen, go grayish like it's going to continue to start up and then black. And it will repeat until I turn it off manually
由完成的
添加一条评论
6个答案
已选择的解决方案
Amanda, connect an external monitor and see what it does. If an external monitor displays correctly, you know that you are having a working GPU ( graphic processor is part of your motherboard) Without actually seeing your screen, it does sound like a bad inverter or bad CCFL's in your LCD panel. Download the service manual from the bottom of this page. I would replace the inverter first (less expensive) if that does not work replace the LCD panel. Should your external monitor not show anything or behave like your LCD display, you are having GPU issues and this would require a motherboard repair. Hope this helps, good luck
这个答案有帮助吗?
得分 4
添加一条评论
If you regularly use your computer for prolonged periods of time then this will cause the computer to heat up rapidly. It sounds strange but over time the graphics card (typically an intel chipset) can actually melt away from the motherboard. This will eventually cause the graphics card to come away from the motherboard and the connection will be terminated. To fix this use a hairdryer or another heat emitting device and hold it over the graphics card for around 2-3 minutes. If necessary do this for longer but be warned that doing this too long can permanently damage the internals of your laptop. Try to point the hairdryer near the connection between the motherboard and the graphics card.
Source: Experience
Hope this helped!
这个答案有帮助吗?
得分 2
添加一条评论
You should try to boot the computer with a boot disk or usb that has anti-virus software built in. This will start the windows machine and will scan the hard drive for trojans. It will find & remove trojans which may solve the problem. Read More - http://www.howtogeek.com/175234/how-to-u...
Else, you can format the hard drive (only if data is unwanted) to erase the infected drive content. Reinstall the OS and use machine as usual. But if you can't afford to loose data then try to boot the system with DVD mounted with anti-virus. If possible also try to run hardware test to diagnose any H/W issues.
这个答案有帮助吗?
得分 1
添加一条评论
it is probably your ram or cpu or gpu, in that case you will need to replace your moutherboard or see an expert about that.
这个答案有帮助吗?
得分 1
添加一条评论
Change the ram module,commen fault,4gb ddr,fault
这个答案有帮助吗?
得分 0
添加一条评论
hello. I have similar issue with my laptop. after the windows installation it works smoothly and when I install graphics driver my laptop wont start. it will only show windows animated logo on the black screen and screen will run black. I have tried 3 different drivers and I got a chance to start it on one of them but it runs 3 to 5 seconds and screen freezes. do I have to change the mother board? or is it something else
这个答案有帮助吗?
得分 0
1条评论:
Pls I need answers fast. I will appreciate it... My laptop Compaq Presario CQ57 will not display anything on the screen whenever I start the system. It's just blank. It hasn't happened before. Though the system cooling device/fan is not functioning properly. Pls what can I do to fix this?
由完成的
添加一条评论
添加你的答案
Amanda 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 46
总计 19,571
