跳转到主内容
加入维修社区 - 创建账户
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
Any help identifying iPhone 4 (CDMA) component?
Does anyone know which smd component this is?
It's in an iPhone 4 (Verizon - CDMA) that sustained some water damage (which I cleaned). Following this the camera simply wouldn't work anymore, leading me to assume it could be this component (due to how corroded it still is after cleaning board).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
1di0t (;-), that is reference designator L11, which is a 3-terminal Filter, SMD Array and it is used for noise removal from high-speed signal lines. A TDK MEA1608PH270T would be a good match. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
Found it. Thank you very much man!!
完成的
添加一条评论
添加你的答案
1di0t 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 183
