How do I take the Silver cover off
I have a problem with the right headphone and I suspect a wire issue but I need to take the cover off to be like this picture:
http://hackaday.com/2013/12/07/repairing...
Any help is geatly appreciated
Sam soud, to get to the wiring, you will have to remove the parts on the inside, not the outside (silver cover) . Check this quick and dirty guide for a similar model. Hope this helps, good luck.
这个答案有帮助吗?
Thank you for the hint!
I Can cut the wires and replace them from the inside , but it might not work,.
As you can see that the wires extends to the electronic board, I want to reach to the board in order to see if the wires are disconnected ( less likley)
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 926
