跳转到主内容
Repairing Bose On-Ear headphones Wiring
你所需要的
  1. Repairing Bose On-Ear headphones Wiring, Repairing Bose On-Ear headphones Wiring: 步骤 1 中的图像 1,3 Repairing Bose On-Ear headphones Wiring, Repairing Bose On-Ear headphones Wiring: 步骤 1 中的图像 2,3 Repairing Bose On-Ear headphones Wiring, Repairing Bose On-Ear headphones Wiring: 步骤 1 中的图像 3,3
    • Here is the Bose Tricore OE headset. Slightly worn, it does not produce any sound to the right side driver
    • Remove the ear pads by simply applying a bit of force between the ear pads and the housing. The ear pad will simply snap off
    • This shows the snaps that attach the ear pad to the case.
  2. Repairing Bose On-Ear headphones Wiring: 步骤 2 中的图像 1,3 Repairing Bose On-Ear headphones Wiring: 步骤 2 中的图像 2,3 Repairing Bose On-Ear headphones Wiring: 步骤 2 中的图像 3,3
    • With the ear pad removed, the Phillips screws that hold the drive to the case, are now visible.
    • Remove the two screws on top
    • There are two more under the padding on the bottom. Remove those as well.
  3. Repairing Bose On-Ear headphones Wiring: 步骤 3 中的图像 1,3 Repairing Bose On-Ear headphones Wiring: 步骤 3 中的图像 2,3 Repairing Bose On-Ear headphones Wiring: 步骤 3 中的图像 3,3
    • The first two screws are longer than the two from under the padding, so keep them separate.
    • With the screws removed, the driver (speaker) can now simply removed by just folding it over.
    • There is a small PCB to which the driver (speaker) mounts. Check the solder connections of the driver (speaker) to the board, as well as the components on this board. It consist of a few caps, resistors, and a coil.
  4. Repairing Bose On-Ear headphones Wiring: 步骤 4 中的图像 1,3 Repairing Bose On-Ear headphones Wiring: 步骤 4 中的图像 2,3 Repairing Bose On-Ear headphones Wiring: 步骤 4 中的图像 3,3
    • Since both driver (speaker) wiring will be checked, remove the left ear pad as well.
    • Same screw configuration. Two screws on top,
    • two screws under the bottom pad,
  5. Repairing Bose On-Ear headphones Wiring: 步骤 5 中的图像 1,3 Repairing Bose On-Ear headphones Wiring: 步骤 5 中的图像 2,3 Repairing Bose On-Ear headphones Wiring: 步骤 5 中的图像 3,3
    • The Phillips screws are identical and do not need to be separated
    • Remove the driver from the case by simply flipping it to the side.
    • Same PCB on both sides. Check the solder connections from the driver (speaker) to the PCB.
  6. Repairing Bose On-Ear headphones Wiring: 步骤 6 中的图像 1,3 Repairing Bose On-Ear headphones Wiring: 步骤 6 中的图像 2,3 Repairing Bose On-Ear headphones Wiring: 步骤 6 中的图像 3,3
    • Here is the PCB of the right side driver (speaker)
    • Simple setup to test the driver (speaker) Two leads with alligator clips, connect those to an 3.5mm audio jack extension.
    • Use those leads and touch the connector of the driver (speaker) on the PCB. There will be sound if the driver (speaker) is working.
  7. Repairing Bose On-Ear headphones Wiring: 步骤 7 中的图像 1,3 Repairing Bose On-Ear headphones Wiring: 步骤 7 中的图像 2,3 Repairing Bose On-Ear headphones Wiring: 步骤 7 中的图像 3,3
    • Time to disassemble the left side. Remove the ear pad
    • then the two on the bottom.
  8. Repairing Bose On-Ear headphones Wiring: 步骤 8 中的图像 1,3 Repairing Bose On-Ear headphones Wiring: 步骤 8 中的图像 2,3 Repairing Bose On-Ear headphones Wiring: 步骤 8 中的图像 3,3
    • Remove the driver (speaker) from the case
    • Make note off how the audio jack cable is fastened.
    • Remove the audio jack cable from the case. It is simply a rubber plug that is pressed into the case.
  9. Repairing Bose On-Ear headphones Wiring: 步骤 9 中的图像 1,3 Repairing Bose On-Ear headphones Wiring: 步骤 9 中的图像 2,3 Repairing Bose On-Ear headphones Wiring: 步骤 9 中的图像 3,3
    • Check the driver (speaker) the same way as on the left side.
    • On this headset, both drivers worked while being tested, but not when the audio was connected to the audio jack. The jack needed to be replaced.
    • Desolder the audio jack cable by using a soldering wick. Apply flux to the wick prior to unsoldering.
    • Remove the old audio jack cable.
  10. Repairing Bose On-Ear headphones Wiring: 步骤 10 中的图像 1,3 Repairing Bose On-Ear headphones Wiring: 步骤 10 中的图像 2,3 Repairing Bose On-Ear headphones Wiring: 步骤 10 中的图像 3,3
    • Here is the rubber boot that holds the audio jack cable in place.
    • Insert the replacement cable as shown through the boot. Solder the new cable to the PCB.
    • Reassemble the headphones after double checking the solder job. This one also received new ear pads (readily available at online auction sites) and works perfectly.
结论
17等其他人完成本指南。
oldturkey03
于09/29/10注册
791,325 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
35 名成员
创作了603篇指南
3条评论
Hi - Thanks for the guide. I have a left earphone not working, what can I deduce from that? everything looks ok on the right side. Guess it can be the audi jack cable?
James Stratton - 回复
Hi, what should the resistance of the speaker be?
Do you know where I can buy a new speaker?
d_stevens77 - 回复
What is the function of the PCB,
Richard Chang - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 77
总计 93,532
